Network problem - header checksum error -
Mon Apr 17 16:42:18 UTC 2006
Steve Hunt wrote:
>in_cksum() does work (without the delay).
>On Mon, 2006-04-17 at 15:29 +0200, Steve Hunt wrote:
>>I have found that by changing file
>>cpukit/libnetworking/netinet/ip_output.c - by adding a delay just before
>>in_cksum_hdr(ip) - the checksum is correctly calculated and everything
>>works!!!! so perhaps the header is still being changed by the driver at
>>that time? or is everything in the same thread? perhaps 'ip' is pointing
>>directly to the hardware and the registers are not stable???.
Is there any possible way you are seeing some type of caching effect?
PowerPC
systems sometimes get caching issues with NIC drivers in PCI memory space.
>>Very strange ...  but I have not have had time to investigate further
>>yet - but I will also see if using in_cksum() in place of in_cksum_hdr()
>>fixes (hides) the problem.
>>As a side issue - I noticed that when my delay was by adding a 'printf'
>>I had a quite stable time reported by ping (~2ms) - but when I used
>>usleep() the time for ping to return changed in a cyclical and
>>predictable way from 10ms to 1mS !!!!! - would this be expected?  I will
>>do some more tests.
If the usleep() requested falls below the clock tick configured, then it
can't be less than
that.  So a 10msec clock tick means every usleep() < 10 msec will be
rounded up to 1 tick.
>>By the way, my target system is a pc104+ ... not very fast by modern
>>standards.
Fast enough to get into trouble. :)
--joel
>>Steve Hunt
>>On Fri, 2006-04-14 at 18:15 +0200, Steve Hunt wrote:
>>>No - it looks like only the header checksum is wrong.
>>>On Fri, 2006-04-14 at 16:30 +0200, Sylvain Prestavoine wrote:
>>>>----- Original Message -----
>>>>From: "Steve Hunt" <hunt at alceli.ch>
>>>>To: <rtems-users at rtems.com>
>>>>Sent: Friday, April 14, 2006 2:44 PM
>>>>Subject: Network problem - header checksum error -
>>>>>I am having a problem getting rtems to run.  I can boot my application
>>>>>on my pc104 with rtk8139 network chip using pxe boot and grub.
>>>>>However once my application is running (and is therefore now using the
>>>>>rtems network stack not the pxe or grub networking) any packets sent
>>>>>from my system seem to have incorrect header checksum.
>>>>>For instance a ping to the device reports no replies - but ethereal
>>>>>'sniffer' shows the reply packet arriving - but with corrupt header
>>>>>checksum.
>>>>How are other datas, corrupted or no ?
>>>>Perhaps is an endianness problem ?
>>>>-Stan
