old ERC32 docs was Re: RTEMS code documentation references
Jiri Gaisler jiri at gaisler.com
Tue Apr 18 13:40:09 UTC 2006
I believe that the references were made against some
early versions of the 3-chip erc32 docs. I left all
these documents behind when I left the Agency some
5 year ago. The Atmel web page on TSC695 has some
newer version of the docs online though...
Jiri.
Joel Sherrill wrote:
> Luís Henriques wrote:
>> Dear Joel,
>> While analysing the ERC32 specific code from RTEMS, I found 2 references
>> to documentation which I could not trace.  These references are both in
>> file c/src/exec/score/cpu/sparc/erc32.h (still on the old RTEMS tree - I
>> am using 4.5.0 version):
> I am offsite today and can't check my bookshelf to give details if I
> even still have the
> original manual (I think I still do) but I can almost swear it would
> have come from
> whatever ERC32 documentation was available when the port was initially
> done. The initial date on the README in the BSP is 1996/12/02 so it
> would have been
> the revision from that time frame.
> I do recall Jiri sending us multiple sis revisions as they were bring up
> the initial
> CPUs at the same time and finding discrepancies.
> Maybe Jiri has access to this old documentation today.  I will try to
> give a specific
> reference tomorrow.
>> 73 /*
>> 74  *  Trap Types for on-chip peripherals
>> 75  *
>> 76  *  Source: Table 8 - Interrupt Trap Type and Default Priority
>> Assignments
>> 77  *
>> 78  *  NOTE: The priority level for each source corresponds to the least
>> 79  *        significant nibble of the trap type.
>> 80  */
>> 81
>> 82 #define ERC32_TRAP_TYPE( _source )
>> SPARC_ASYNCHRONOUS_TRAP((_source) + 0x10)
>> 90 /*
>> 91  *  Structure for ERC32 memory mapped registers.
>> 92  *
>> 93  *  Source: Section 3.25.2 - Register Address Map
>> 94  *
>> 95  *  NOTE:  There is only one of these structures per CPU, its base
>> address
>> 96  *         is 0x01f80000, and the variable MEC is placed there by the
>> 97  *         linkcmds file.
>> 98  */
>> Of course, these references refer to ERC32 documentation.  Could you
>> please provide me with the exact documents reference (name, version,
>> date, ...)?
>> Thanks a lot.
>> Luís Henriques
