Problems building RTEMS for M68k in CYGWIN environment
Swain, Mark T mark.t.swain at delphi.com
Mon Apr 24 14:59:16 UTC 2006
All,
Thank you very much for your help.  I did verify that I can compile a simple program using the the cross compiler (m68k-rtems-gcc) by following the instructions in the "Getting Started with RTEMs" tutorial.  The "f.c" code assembled and later compiled ok.  Is this the compiler (gcc) that acutally builds the rtems application?  I also did an "env" to see if there was problems with incorrect variables being set.   Didn't see anything unusual, no LIB or CC set.
The following shows an exert of the config.log file.  From the file it looks like the problem is related to "/bin/ld: cannot find -luser32".  I'm not really sure what the -luser32 is referring to.  I haven't got a chance to try Sreejith idea at this point.  Again, thanks for the help and let me know if you have any ideas.
Thanks,
Mark
gcc version 3.3.3 (cygwin special)
configure:2192: $? = 0
configure:2194: gcc -V </dev/null >&5
gcc: `-V' option must have argument
configure:2197: $? = 1
configure:2220: checking for C compiler default output file name
configure:2223: gcc    conftest.c  >&5
collect2: ld returned 1 exit status
configure:2226: $? = 1
configure: failed program was:
| /* confdefs.h.  */
| #define PACKAGE_NAME "rtems-tools-build"
| #define PACKAGE_TARNAME "rtems-tools-build"
| #define PACKAGE_VERSION "4.6.5"
| #define PACKAGE_STRING "rtems-tools-build 4.6.5"
| #define PACKAGE_BUGREPORT "rtems-bugs at rtems.com"
| /* end confdefs.h.  */
| int
| main ()
|   return 0;
configure:2265: error: C compiler cannot create executables
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Sent: Monday, April 24, 2006 9:01 AM
To: sreejith.kurup at patni.com
Cc: rtems-users at rtems.com
Subject: Re: Problems building RTEMS for M68k in CYGWIN environment
> checking for i686-pc-cygwin-gcc.... no
>checking for gcc... gcc
>checking for C compile default output file name... configure: error: C
I am pretty sure this indicates the native compiler is not working.  Can
you
actually compile and run a native "hello world"?
--joel
Sreejith kurup wrote:
>Try making the folder \tmp\rtemsdocs-4.6.5 in the folder b-gcc or the folder
>containing b-gcc.
>regards
>sreejith
>From: Chris Welch [mailto:cwelch at neumes.com]
>Sent: Saturday, April 22, 2006 10:51 PM
>To: rtems-users at rtems.com
>Subject: RE: Problems building RTEMS for M68k in CYGWIN environment
>Watch out for definitions for the Microchip tools as well.  I got badly
>burned with very strange make errors that took a couple of days to isolate
>to the definitions set up for Microchip tools.
>I believe you'll find them if you search for anything with MCC in your
>environment variables.
>Chris Welch, Neumes Consulting, PC and UNIX Solutions
>mailto:cwelch at neumes.com (613)797-7831 FAX:(613)838-5602
>http://www.neumes.com
>Sent: Friday, April 21, 2006 11:17 AM
>To: Swain, Mark T
>Cygwin sometimes inherits environment variables from Windows that are
>specific
>to Visual Studio and confuse GCC.  Do a "env" command and look for variables
>like CC, LIBS, etc that are set.
>But you need to also make sure you can compile and run a native hello world.
>That's what appears to have failed.  Look in config.log for details.
>--joel
>Swain, Mark T wrote:
>>Hello all,
>>Please forgive the ignorant questions but I'm a "newbie" to RTEMS and
>trying to get past the learning curve. At this point I'm just trying to
>install rtems 4.6.5 for a m68k target (actually its a M68377, CPU32 based)
>and a gen68340 BSP. The host I'm using is a Windows XP machine running
>CYGWIN.
>>I've been following the instructions as detailed in the "Getting Started
>with RTEMS" documentation and all has went as planned until now. I'm having
>problems with the actual building of RTEMS (Chapter 5). Specifically the
>problem appears to be when I attempt to configure the environment. The
>configure command I'm executing looks like the following:
>>../rtems-4.6.5/configure --target=m68k-rtems --enable-rtembsp=gen68340
>>That resulted in the checking of several prereqs but fails at the gcc check
>with the following error:
>>See 'config.log' for more details
>>configure: error: /bin/sh '../../../rtems-4.6.5/tools/build/configure'
>failed for tools/build
>>I can't find any relavant info in the config.log file. I don't understand
>the error. Is RTEMS looking for gcc and can't find it? I checked the path
>and it appears to point to the correct locations. Any ideas???
>>Mark
>>Note:  If the reader of this message is not the intended recipient, or an
>employee or agent responsible for delivering this message to the intended
>recipient, you are hereby notified that any dissemination, distribution or
>copying of this communication is strictly prohibited. If you have received
>this communication in error, please notify us immediately by replying to the
>message and deleting it from your computer. Thank you.
>http://www.patni.com
>World-Wide Partnerships. World-Class Solutions.
>_____________________________________________________________________
>This e-mail message may contain proprietary, confidential or legally
>privileged information for the sole use of the person or entity to
>whom this message was originally addressed. Any review, e-transmission
>dissemination or other use of or taking of any action in reliance upon
>this information by persons or entities other than the intended
>recipient is prohibited. If you have received this e-mail in error
>kindly delete  this e-mail from your records. If it appears that this
>mail has been forwarded to you without proper authority, please notify
>us immediately at netadmin at patni.com and delete this mail.
Note:  If the reader of this message is not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us immediately by replying to the message and deleting it from your computer. Thank you.
