FTP Server busy waiting when file descriptors are exhausted
Chris Johns
chrisj at rtems.org
Tue Apr 4 13:08:41 UTC 2006
Thomas Rauscher wrote:
> there has been little discussion so far. I still cannot see a clean way
> to remove pending connections in the listen socket (besides closing it).
I asked a question about the networking stack and the case of no
available fd's when in an accept call. I have found the code for RTEMS
in cpukit/libnetworking/rtems/rtems_syscall.c:
fd = rtems_bsdnet_makeFdForSocket (so, &socket_handlers);
if (fd < 0) {
TAILQ_INSERT_HEAD(&head->so_comp, so, so_list);
head->so_qlen++;
soconnwakeup (head);
rtems_bsdnet_semaphore_release ();
return -1;
If there is no fd available the socket is placed back on the listen list.
Is this the best solution for RTEMS ?
I checked NetBSD's kernel and it will return an error from accept if the
number of fd's for the process has reached its limit. A log message is
generated. If there is no space the fd allocator blocks waiting. It
looks like FreeBSD is the same.
If you limit the number of fd's as task has (ulimit), use up the fd's in
a similar way as the test case then try and accept a connection the same
error will appear. How-ever on Unix the machine should not have locked
up just the task.
Possible solutions are:
1) The proposed patch.
2) Drop the connection if no fd is present (close the socket placed on
the listen queue).
3) Block in the fd allocator (rtems_bsdnet_makeFdForSocket) until an fd
appears. This could be for-ever or just a period of time.
4) Other suggestions.
Regards
