PCP implementation
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Apr 7 11:07:57 UTC 2006
Till Straumann wrote:
> I still consider this a design flaw. However,
> vxWorks seems to do the same thing. I couldn't
> test but the manual (semMLib) still (as of
> vxWorks 5.5 says
> "Once the task priority has been
> elevated, it remains at the higher level until all
> mutual-exclusion semaphores that the task owns
> are released; then the task returns to its normal,
> or standard, priority."
> And a little further down:
> "The task will return to its normal priority only
> after relinquishing all of its mutual-exclusion
> semaphores that have the inversion-safety option
> enabled."
I'm certainly willing to do something more theoretically correct if
we can identify an algorithm that is efficient to implement.
--joel
> -- Till
>>> I agree and I consider this a major design flaw.
>>> Indeed: by looking at the source code and testing
>>> your example I can confirm the documented
>>> behavior.
>>> Note that priority-inheriting binary semaphores
>>> exhibit the same flaw.
>>> When surrendering a priority-ceiling or -inheriting
>>> mutex the executing task priority should be changed
>>> to the highest priority (ceiling or inherited) of all currently
>>> held mutexes.
>> This is the designed and documented behavior. To implement otherwise
>> would require maintaining information on the set of held resources and
>> analyzing that set each time a mutex is released. The current design is
>> an engineering tradeoff assuming that you don't nest lots of PCP/PI
>> mutexes
>> and don't hold them for lengthy periods of time.
>> I recently thought about this and think the "resources held set"
>> could be
>> cheaply maintained but how you determine the appropriate priority when
>> you release a mutex is still painful. Even if you maintain the set as a
>> stack/LIFO and imposed and enforced the rule that
>> PCP/PI mutexes were released in the opposite order of acquisition,
>> I still think you would have to scan the set when you released a mutex
>> to find out what the highest priority to inherit is.
>> Any thoughts on an efficient way to implement the set management
>> required is appreciated. I have trouble seeing it as something that is
>> constant order execution time.
>> --joel
>>> -- Till
>>> Martin Molnar wrote:
>>>> Hi,
>>>> Could anybody explain me how exactly Priority Ceiling Protocol
>>>> (PCP) is implemented in RTEMS? I think it works differently than
>>>> PCP described in technical books.
>>>> Example:
>>>> 1.Task1 (current priority 10) obtains the mutex SEM1 and its
>>>> priority is raised to the mutex ceiling (9).
>>>> 2.Task1 ( current priority 9) obtains the mutex SEM2 and its
>>>> priority is raised to the mutex ceiling (5).
>>>> 3.Task1 ( current priority 5) releases the mutex SEM2. I would
>>>> expect the priority to be changed to value 9. However, the priority
>>>> remains unchanged. From RTEMS documentation: Only when the task
>>>> releases ALL of the binary semaphores it holds will its priority be
>>>> restored to the normal value.
>>>> I am not sure, whether RTEMS PCP(and also Priority Inheritance
>>>> Protocol) is correct. Because,now Task1 can block for example TAsk2
>>>> with priority 6.
>>>> Thanks for explanation
>>>> Martin Molnar
