PCP implementation
Till Straumann strauman at slac.stanford.edu
Sat Apr 8 03:03:05 UTC 2006
Pavel Pisa wrote:
>Hello All,
>On Saturday 08 April 2006 01:36, Martin Molnar wrote:
-- snip --
>>What about implementing the changing of task`s priority this way:
>>-enforce the mutex release rule that PCP mutexes are released in the
>>opposite order  of acquisition. I think , it is not a painful restriction.
Sorry for not reading entirely through your suggenstions but IMO we have
to stop right here. I do not agree with the premise. I don't think that this
restriction is acceptable. Think about a scenario where you have a
small critical section protected by a 'fine-grained' mutex. Part of the
critical code section is acquisition of a 'coarse' mutex:
   lock(fine_grained)
      do_critical_work()
      lock(coarse)
   unlock(fine_grained)
      do_coarsely_protected_work()
   lock(fine_grained)
       unlock(coarse)
       do_critical_cleanup()
Easy to imagine such a situation -> stack approach is not acceptable.
-- Till
>>- for each task, maintain the "resources held set" implemented as stack.
>>  Every stack element(record) consists of two fields: the mutex id (to
>>control that the mutex relase rule is kept) and task`s priority after
>>releasing that mutex.
>The stack of fixed size is bad programmers practice.
>OK, you have task stack of fixed sizes, but it already stroked
>to Joel and others by mysterious PC port fails.
>>For better explation, consider the example:
>>- task`s normal priority is 9.
>>1. Task acquires mutex 4 ( 4 is the ceiling of mutex). Then,put on the
>>stack element(mutex id= 4   priority= current priority=9 ) and change
>>task`s current priority to 4.
>>2.Task acquires mutex 8. Then put on the stack element(mutex id= 8
>>priority=current priority= 4 ). Task`s current priority is not changed
>>because it is higher than 8.
>>Example of the stack:
>>mutex id: 4 8 6 2 1
>>priority: 9 4 4 4 2
>OK, I am not sure, if you counted for what has to happen
>when task with priority 3 wants to overtake mutex 8,
>your queues has to be adjusted to
>mutex id: 4 8 6 2 1
>priority: 9 4 3 3 3
>no change of actual task's priority, if task with priority
>1 arrives now and asks for mutex 6, situation changes
>mutex id: 4 8 6 2 1
>priority: 9 4 3 1 1
>and actual task priority has to be adjusted.
>To build LIFO list, I would suggest to add only
>one pointer to latest acquired mutex to the task structure
>and pointer and priority fields to each mutex.
>The last piece is identifier of actual holding thread
>(but it is there already).
>Mutex (by the definition) guarantees, that only one thread
>of execution can hold it. This means, that no other thread
>can use mutex private fields if they are assigned to actual
>holding thread.
>the mutex lock code
>  if mutex is available
>    mutex->prev_acquired=task->last_mutex
>    task->last_mutex=mutex
>    mutex->prev_prio=task->prio
>    mutex->holder=task->id
>    adjust priority for ceiling
>  else
>    if mutex->prev_prio<thread->prio
>      resolve mutex->holder
>      m=holder->last_mutex
>      while m!=mutex
>          mutex->prev_prio=thread->prio
>        m=mutex->prev_acquired
>      if holder->prio < thread->prio
>        escalate holder->prio to thread->prio
>>It`s obvious how to release mutexes and change task`s priority.
>Simple and O(1), but I am not sure, if above described complexity
>worth to be implemented. The
>The above algorithm can work even for recursive mutexes,
>the whole acquisition of mutex is skipped if holder is actual
>task and only recursion count is increased. This is as it is
>implemented in RTEMS now.
>The code can be speed up little, if priority stack is shifted
>by one and first stage is stored directly in the TCB.
>This way new attempting task is informed more quickly
>that actual mutex priority is already escalated and
>gets the value of that escalation => it does not to need
>to go through list to find that fact in the mutex
>pointing exactly to the mutex in the question.
>This code can even work for different order of release
>than acquisition:
>  if task->last_mutex == mutex
>    task->last_mutex = mutex->prev_acquired
>    change task->prio to mutex->prev_prio
>       (little more complex with shifted priority stack)
>  else
>    go from task->last_mutex and find neiborhoods
>    of mutex and adjust list accordinly
>    the priority adjustment is problem in this situation,
>    with shifted stack it is feasible and simpler
>If you think, that it worths the complexity, I can try to help
>to implement it. But I am not sure, if this is not something,
>which should be configurable. Good code tries to hold
>mutexes for minimal necessary time, does not call more functions
>with mutex hold etc etc. In other case, there are problems with
>missed deadlock possibilities which creep into code as result
>of other pieces adjustments ... . So I think, that for carefully
>written code and applications actual solution could be
>even more profitable than fully correct one.
>Other possibility is to select this option on per mutex basis.
>Best wishes
>           Pavel Pisa
