RTEMS message queues and interrupt safety
SERONIE VIVIEN, Jacques
jacques.seronievivien at astrium.eads.net
Thu Apr 20 07:13:57 UTC 2006
I think that this has been fixed by the correction of PR820:
http://www.rtems.com/cgi-bin/gnatsweb.pl?debug=&database=default&cmd=view+audit-trail&pr=820
Hope it helps,
Jacques.
-----Original Message-----
From: Thomas Doerfler [mailto:Thomas.Doerfler at imd-systems.de]
Sent: Tuesday, April 18, 2006 8:44 PM
To: Phil Torre
Cc: RTEMS User List
Subject: Re: RTEMS message queues and interrupt safety
Phil,
we had a similar leak in critical code boundaries some weeks ago, it was
filed in the bug database under PR904. Maybe this would fix things for
you too?
http://www.rtems.com/cgi-bin/gnatsweb.pl?cmd=view%20audit-trail&database=default&pr=904
wkr,
Thomas.
Phil Torre wrote:
> Greetings All,
> We've got a weird bug that may interest someone. I'd be interested in
> hearing from anyone who has seen similar.
> The setup: rtems-4.6.0 with various patches merged in from CVS,
> running on MPC855T, with an unsubmitted BSP.
> The PowerPC host processor receives interrupts from an external DSP at
> a fairly high rate. The ISR that services that interrupt sends
> messages to a queue that is read by a "classic API" task. Several
> other foreground tasks also send messages to that queue. When running
> at high load (lots of interrupts firing) for extended periods of time,
> we sometimes see messages that have already been read from the queue
> "reappear", as much as tens of milliseconds later. This seems to be
> happening because the number_of_pending_messages member of the
> CORE_message_queue_Control struct is zero, but the chain of pending
> messages is non-empty. When a new message is submitted, it goes to
> the end of the chain, and number_of_pending_messages becomes 1. The
> next time the queue is read, the count is decremented back to zero,
> but the wrong message is returned.
> I don't know exactly how the "count is zero but list is not empty"
> condition comes about. I put in a bunch of instrumentation to try and
> catch it in the act of happening. But, interrupts firing in the
> middle of my debug code was causing my debug code to false trigger.
> So, I resorted to turning interrupts off for the entire duration of
> both _CORE_message_queue_Submit() and _CORE_message_queue_Seize(). Now
> my debug code doesn't false-trigger, but the actual bug doesn't happen
> any more. We got pretty good at reproducing it, but with interrupts
> disabled in those two functions, we can't make the bug manifest any
> more. I don't know if I have actually fixed something, or just forced
> the bug into hiding, biding its time.
> Looking at the queue insert/remove code, I don't see a window. I may
> be missing it, or there may not be one there and I've just changed the
> timing enough with my interrupt disabling that we can't make the bug
> show itself the same way.
> Any comments would be welcome.
> Thanks,
> -Phil
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at:
http://www.imd-systems.de/pgpkey_en.html
CE COURRIER ELECTRONIQUE EST A USAGE STRICTEMENT INFORMATIF ET NE SAURAIT ENGAGER DE QUELQUE MANIERE QUE CE SOIT EADS ASTRIUM SAS, NI SES FILIALES.
SI UNE ERREUR DE TRANSMISSION OU UNE ADRESSE ERRONEE A MAL DIRIGE CE COURRIER, MERCI D'EN INFORMER L'EXPEDITEUR EN LUI FAISANT UNE REPONSE PAR COURRIER ELECTRONIQUE DES RECEPTION. SI VOUS N'ETES PAS LE DESTINATAIRE DE CE COURRIER, VOUS NE DEVEZ PAS L'UTILISER, LE CONSERVER, EN FAIRE ETAT, LE DISTRIBUER, LE COPIER, L'IMPRIMER OU EN REVELER LE CONTENU A UNE TIERCE PARTIE.
This email is for information only and will not bind EADS Astrium SAS in any contract or obligation, nor its subsidiaries.
If you have received it in error, please notify the sender by return email. If you are not the addressee of this email, you must not use, keep, disseminate, copy, print or otherwise deal with it.
