Problems building RTEMS for M68k in CYGWIN environment
Chris Welch cwelch at neumes.com
Sat Apr 22 17:20:35 UTC 2006
Watch out for definitions for the Microchip tools as well.  I got badly
burned with very strange make errors that took a couple of days to isolate
to the definitions set up for Microchip tools.
I believe you'll find them if you search for anything with MCC in your
environment variables.
Chris Welch, Neumes Consulting, PC and UNIX Solutions
mailto:cwelch at neumes.com (613)797-7831 FAX:(613)838-5602
http://www.neumes.com
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Sent: Friday, April 21, 2006 11:17 AM
To: Swain, Mark T
Cc: rtems-users at rtems.com
Subject: Re: Problems building RTEMS for M68k in CYGWIN environment
Cygwin sometimes inherits environment variables from Windows that are
specific
to Visual Studio and confuse GCC.  Do a "env" command and look for variables
like CC, LIBS, etc that are set.
But you need to also make sure you can compile and run a native hello world.
That's what appears to have failed.  Look in config.log for details.
--joel
Swain, Mark T wrote:
>Hello all,
>Please forgive the ignorant questions but I'm a "newbie" to RTEMS and
trying to get past the learning curve. At this point I'm just trying to
install rtems 4.6.5 for a m68k target (actually its a M68377, CPU32 based)
and a gen68340 BSP. The host I'm using is a Windows XP machine running
CYGWIN.
>I've been following the instructions as detailed in the "Getting Started
with RTEMS" documentation and all has went as planned until now. I'm having
problems with the actual building of RTEMS (Chapter 5). Specifically the
problem appears to be when I attempt to configure the environment. The
configure command I'm executing looks like the following:
>../rtems-4.6.5/configure --target=m68k-rtems --enable-rtembsp=gen68340
>That resulted in the checking of several prereqs but fails at the gcc check
with the following error:
>checking for i686-pc-cygwin-gcc.... no
>checking for gcc... gcc
>checking for C compile default output file name... configure: error: C
compiler cannot create executables
>See 'config.log' for more details
>configure: error: /bin/sh '../../../rtems-4.6.5/tools/build/configure'
failed for tools/build
>I can't find any relavant info in the config.log file. I don't understand
the error. Is RTEMS looking for gcc and can't find it? I checked the path
and it appears to point to the correct locations. Any ideas???
>Mark
>Note:  If the reader of this message is not the intended recipient, or an
employee or agent responsible for delivering this message to the intended
recipient, you are hereby notified that any dissemination, distribution or
copying of this communication is strictly prohibited. If you have received
this communication in error, please notify us immediately by replying to the
message and deleting it from your computer. Thank you.
