Strange error while building binutils
Ali Asgar Nasir aliasgar.nasir at patni.com
Wed Aug 2 07:17:58 UTC 2006
binutils-2.13.2.1
rtems 4.6.6
command line used for configuring binutils
configure --target=m68-rtems --prefix=/rtems-docs4.6.6
command line used for building
make all
make info
make install
i get the error when i give the make all command.
Regards
ali
----- Original Message -----
From: "Paul Whitfield" <paulw at omnitronics.com.au>
To: "Ali Asgar Nasir" <aliasgar.nasir at patni.com>
Cc: "RTEMS - Mailing List" <rtems-users at rtems.com>
Sent: Wednesday, August 02, 2006 12:24 PM
Subject: Re: Strange error while building binutils
> Ali Asgar Nasir wrote:
>> Hi
>> i get the following strange error while building binutils. can anyone
>> guide=
>> how to remove this error.
>> i am using gnu make 3.80 on cygwin, GCC version 3.4.4
>> Regards
>> ali
>> ../../binutils-2.13.2.1/libiberty/regex.c:5175: error: dereferencing
>> pointe=
>> r to
>> incomplete type
>> ../../binutils-2.13.2.1/libiberty/regex.c:5176: error: dereferencing
>> pointe=
>> r to
>> incomplete type
>> ../../binutils-2.13.2.1/libiberty/regex.c:5178: error: dereferencing
>> pointe=
>> r to
>> incomplete type
>> ../../binutils-2.13.2.1/libiberty/regex.c:5179: error: dereferencing
>> pointe=
>> r to
>> incomplete type
>> ../../binutils-2.13.2.1/libiberty/regex.c:5199: error: dereferencing
>> pointe=
>> r to
>> incomplete type
>> ../../binutils-2.13.2.1/libiberty/regex.c:5285: error: dereferencing
>> pointe=
>> r to
>> incomplete type
>> ../../binutils-2.13.2.1/libiberty/regex.c:5324: error: dereferencing
>> pointe=
>> r to
>> incomplete type
> I think you need to provide more information before anyone will be
> able to help.
> Please provide;
> RTEMS version
> Binutils version
> command line you used for configuring / building.
> ALSO: AFAIK Cygwin is a temperamental build host.
> Regards
> Paul
> The information in this e-mail is intended for the addressee only.
> Unauthorised use, copying, disclosure or distribution by anyone else
> is prohibited. Please let us know immediately if you receive this
> e-mail in error. Thank you.
http://www.patni.com
World-Wide Partnerships. World-Class Solutions.
_____________________________________________________________________
This e-mail message may contain proprietary, confidential or legally
privileged information for the sole use of the person or entity to
whom this message was originally addressed. Any review, e-transmission
dissemination or other use of or taking of any action in reliance upon
this information by persons or entities other than the intended
recipient is prohibited. If you have received this e-mail in error
kindly delete  this e-mail from your records. If it appears that this
mail has been forwarded to you without proper authority, please notify
us immediately at netadmin at patni.com and delete this mail.
