RTEMS4.7 CVS (was Re: Motorola roadmap)
Kate Feng feng1 at bnl.gov
Fri Aug 4 14:19:11 UTC 2006
Kate Feng wrote:
> Kate Feng wrote:
> > This is what Motorola  responded :
> > "The current roadmap shows the 5500 and the 6100 with the same
> > life cycle."
> I forgot to mention that there was a formal presentation about the
> performance of  RTEMS-MVME5500 BSP at :
> http://icalepcs2005.web.cern.ch/Icalepcs2005/Presentations/11oct_Tuesday/TU4A/TU4A_1-5O.ppt
> The associated  paper  is  published at :
> http://elise.epfl.ch/pdf/O2_011.pdf
I downloaded the RTEMS4.7 CVS on  Tues., Aug. 1, and found
out that  on Nov. 3, 2005, the make/custom/mvme5500.cfg  was updated
so that :
"CPU_CFLAGS = -mcpu=7450 -Dmpc7455 ......."
became :
"CPU_CFLAGS = -mcpu=750 ......"
May I know why ?  I am not sure if the later  one is OK.   I always
used the " CPU_CFLAGS = -mcpu=7450 -Dmpc7455 ......".
Also, The mvme5500 BSP is not up-to-date as the one posted on the web :
http://www.nsls.bnl.gov/facility/expsys/software/EPICS/
The  above mentioned paper is based on the RTEMS-4.6.0-MVME5500
source posted at:
The only known bug (cavet : probably due to my not
up-to-date version of cexp/GeSys) is that :
/usr/local/source/RTEMS/rtems-4.6.x/cpukit/aclocal/canonicalize-tools.m4.orig
/usr/local/source/RTEMS/rtems-4.6.x/cpukit/wrapup/Makefile.am.orig
/usr/local/source/RTEMS/rtems-4.6.x/c/src/wrapup/Makefile.am.orig
are needed to build the original RTEMS release.
After  RTEMS is built, then the
has to be copied back to build the cexp/GeSys.
This is documented under synAppsRTEMS/R3.14.6.cexp_patch/patches.
I will put the warning in a more obvious place on the WEB for rtems-4.6.x.
However, I do not know if this cavet still applies in RTEMS4.7  because
I did'nt try it yet.
Since I have no write permission to the RTEMS4.7CVS, I will
put up an updated version of RTEMS-MVME5500 BSP for the
RTEMS4.7 on the
Regards,
Kate
