possible SPARC cpu_asm.S error
Jerry Needell
jerry.needell at unh.edu
Tue Aug 15 12:26:26 UTC 2006
I think I have found an error in the cpukit/score/cpu/sparc/cpu_asm.S
code. When writing to the PSR, a sequence of three NOP's must be added
to ensure that the PSR value is properly set after running through the
pipeline. This is done in most places in cpu_asm.S but was left out in a
few and, I think, causing me some problems. I have been trying to track
down and intermittent crash for a long time! My application was crashing
after servicing an interrupt. cpu_asm.S includes ISR_Dispatch which was
missing the NOP's ater setting the PSR before returning.
The problem became much worse when I tried rebuilding 4.6.99.3 using
the -mcpu-v8 flag to take advantage of the SPARC V8 multiply in the
LEON3. The diff attached also has the change I made to
make/custom/leon3.cfg to set the -mcpu=v8 switch.
The cpu-asm.S error should apply to all SPARC cpu's (v7 or v8).
- Jerry
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20060815/a9536d88/attachment.ksh>
