YAFFS or JFFS for RTEMS
Ed Sutter esutter at lucent.com
Fri Aug 18 12:57:14 UTC 2006
Alexander,
Not sure what you need, but if you use MicroMonitor as the bootloader,
then it comes with TFS (not POSIX compatible) which is a pretty mature
FFS that is powersafe and has been used with RTEMS.
What kind of storage requirements do you have?
Ed
Jay Monkman wrote:
> Alexander I. Shaykhrazeev wrote:
>>Is there another POSIX compatible fs for RTEMS?
> I don't know of any other supported filesystems than the IMFS and DOSFS.
>>What kind of media are you using? We are using DiskOnChip G3/G4 (with
>>modified TrueFFS/SureFS) and planing to migrate to Intel StrataFlash P3.
> I've used StrtaFlash and Atmel flash. Both are NOR flash. I haven't tried any
> variety of NAND flash.
