RES: CPU Supplement Reorg Proposal
Fabrício de Novaes Kucinskis fabricio at dea.inpe.br
Tue Aug 22 11:30:54 UTC 2006
[From Paul:]
>> Since no one else is commenting I will.
I've already commented, but in the thread that originated this discussion.
As many of the interested people had not read, I'm "re-commenting" here ;)
[From Joel:]
>> So I am proposing that this information [sizing and timing information]
be eliminated from the supplements.
>> Along with this I am proposing that the remaining information in the
supplements be merged into a single
>>  document with one chapter per architecture supported.
I agree that it's better to have just one CPU Supplement document. But the
size info is important and must be kept. However, I think that in most cases
there's no need of knowing the exact size of an application. As it is
difficult to maintain this info updated, I suggest a table with the size of
a typical HelloWorld example compiled for each BSP, instead of the current
list with the size of each manager, which doesn't reflect the size of a
RTEMS application.
The size of the HelloWorld will not change so much between versions, and a
warning explaining that "the sizes listed here is just an example, and can
vary a little" can help.
Regards,
Fabrício.
-----Mensagem original-----
De: Paul Whitfield [mailto:paulw at omnitronics.com.au]
Enviada em: segunda-feira, 21 de agosto de 2006 22:27
Para: Joel Sherrill
Cc: RTEMS Users Mailing List
Assunto: Re: CPU Supplement Reorg Proposal
All sound perfect to me.
Regards
Paul
Senior Software Engineer.
Omnitronics P/L
15 Hector Street
Osborne Park
WA 6017
Australia
Ph: +61 8 9445 2633
Fx: +61 8 9445 1687
www.omnitronics.com.au
The information in this e-mail is intended for the addressee only.
Unauthorised use, copying, disclosure or distribution by anyone else
is prohibited. Please let us know immediately if you receive this
e-mail in error. Thank you.
