Networking support for Linux target
Ali Asgar Nasir aliasgar.nasir at patni.com
Wed Aug 23 03:50:49 UTC 2006
Navin,
The confiure command should contain the target processor on which u r going
to port the OS. The Pentium machine which u r using is the host
machine...What is your final target on which u want to port the OS? If it is
the same home machine(Pentium), then the configure command should have the
field "-enable-rtemsbsp = i386-rtems".
Regards
Ali
----- Original Message -----
To: "Ali Asgar Nasir" <aliasgar.nasir at patni.com>; <rtems-users at rtems.com>
Sent: Tuesday, August 22, 2006 9:06 PM
Subject: RE: Networking support for Linux target
> Ali,
> I'm trying to build on a Pentium PC running Linux, which does support
> networking.
> So, what should my "configure" command be?
> Thanks,
> Navin
> -----Original Message-----
> From: Ali Asgar Nasir [mailto:aliasgar.nasir at patni.com]
> Sent: Tuesday, August 22, 2006 6:03 AM
> To: Navin Garg; rtems-users at rtems.com
> Subject: Re: Networking support for Linux target
> Hi,
> what is ur target processor? Does it support networking?
> In the command of configure what follows the command
> "-enable-rtemsbsp="?
> What do mean by linux target? Ur target should be a processor or a
> processor
> family and not an OS like linux.
> Regards
> Ali
> From: "Navin Garg" <ngarg at mykotronx.com>
> To: <rtems-users at rtems.com>
> Sent: Monday, August 21, 2006 8:57 PM
> Subject: Networking support for Linux target
>> Hi,
>> I built RTEMS under linux and want to use linux as the target. The
> build
>> appeared to succeed however, there is no networking support even
> though
>> I had specified "--enable-networking".
>> I used the following configure command:
>> ./configure --disable-itron --enable-networking -enable-rtemsbsp=
>> --enable-tests --enable-docs --disable-cxx
>> Can I not include networking support for a linux target? Or, is there
>> something wrong with this configure command?
>> Any help would be greatly appreciated.
>> Thanks,
>> Navin
> http://www.patni.com
> World-Wide Partnerships. World-Class Solutions.
> _____________________________________________________________________
> This e-mail message may contain proprietary, confidential or legally
> privileged information for the sole use of the person or entity to
> whom this message was originally addressed. Any review, e-transmission
> dissemination or other use of or taking of any action in reliance upon
> this information by persons or entities other than the intended
> recipient is prohibited. If you have received this e-mail in error
> kindly delete  this e-mail from your records. If it appears that this
> mail has been forwarded to you without proper authority, please notify
> us immediately at netadmin at patni.com and delete this mail.
