RTEMS test suite problems in 4.6.6?
Kenneth J. Peters
Kenneth.J.Peters at jpl.nasa.gov
Wed Aug 23 17:47:13 UTC 2006
I'm updating from RTEMS 4.5.0 to RTEMS 4.6.6 (sparc erc32 based BSP),
and I am running the test suite (sptests, tmtests, and some of the
other tests).
I find that SP20 and the "unlimited" tests fail from the 4.6.6 build,
though they pass from the 4.5.0 build. See failing results below.
I also notice that SP16 does not produce quite the expected output on
either build (TA3 waits for memory but does not get it before being
deleted, unlike the sp16.scn file). See "failing" results below.
Has anyone seen similar behavior, erc32 or not? I don't see anything
in the bug database that sounds like these issues. I have to
definitively determine whether these indicate that my 4.6.6 is built
incorrectly, or if these are problems with 4.6.6 as "shipped".
Ken Peters
Ken.Peters at jpl.nasa.gov
SP20 from 4.6.6 produces:
>*** TEST 20 ***
>TA1 - rtems_rate_monotonic_create id = 0x42010001
>TA1 - rtems_rate_monotonic_ident id = 0x42010001
>TA1 - (0x42010001) period 2
>TA2 - rtems_rate_monotonic_create id = 0x42010002
>TA2 - rtems_rate_monotonic_ident id = 0x42010002
>TA2 - (0x42010002) period 2
>TA3 - rtems_rate_monotonic_create id = 0x42010003
>TA3 - rtems_rate_monotonic_ident id = 0x42010003
>TA3 - (0x42010003) period 2
>TA4 - rtems_rate_monotonic_create id = 0x42010004
>TA4 - rtems_rate_monotonic_ident id = 0x42010004
>TA4 - (0x42010004) period 2
>TA5 - rtems_rate_monotonic_create id = 0x42010005
>TA5 - rtems_rate_monotonic_ident id = 0x42010005
>TA5 - (0x42010005) period 100
>TA6 - rtems_rate_monotonic_create id = 0x42010006
>TA6 - rtems_rate_monotonic_ident id = 0x42010006
>TA6 - (0x42010006) period 0
>rtems_rate_monotonic_period FAILED -- expected (successful
>completion) got (timed out waiting)
but works fine from 4.5.0
"unlimited" section "TEST3" is only able to make 50 tasks before running out:
> TEST3 : creating task 'aa46', number = 46, id = 0a010030,
>starting, task 46 has started.
> TEST3 : creating task 'aa47', number = 47, id = 0a010031,
>starting, task 47 has started.
> TEST3 : creating task 'aa48', number = 48, id = 0a010032,
>starting, task 48 has started.
> TEST3 : creating task 'aa49', number = 49, id = 0a010033,
>starting, task 49 has started.
> TEST3 : creating task 'aa50', failure, unsatisfied.
> FAIL3 : not enough tasks created -
> task created = 50, required number = 55
SP16 produces:
>*** TEST 16 ***
>TA1 - rtems_region_ident - rnid => 32010002
>TA1 - rtems_region_get_segment - wait on 100 byte segment from region 2
>TA1 - got segment from region 2 - 0x00000f70
>TA1 - rtems_region_get_segment - wait on 3K segment from region 3
>TA1 - got segment from region 3 - 0x000003c0
>TA1 - rtems_region_get_segment - get 3080 byte segment from region 1 - NO_WAIT
>TA1 - got segment from region 1 - 0x00000320
>TA1 - rtems_task_wake_after - yield processor
>TA2 - rtems_region_get_segment - wait on 2K segment from region 1
>TA3 - rtems_region_get_segment - wait on 3968 byte segment from region 2
><pause>
>TA1 - rtems_region_return_segment - return segment to region 1 - 0x00000320
>TA1 - rtems_region_get_segment - wait 10 seconds for 3K segment from region 1
>TA2 - got segment from region 1 - 0x000007a0
>TA2 - rtems_region_return_segment - return segment to region 1 - 0x000007a0
>TA2 - rtems_task_set_priority - make self highest priority task
>TA2 - rtems_region_get_segment - wait on 3968 byte segment
>TA1 - got segment from region 1 - 0x000003a0
>TA1 - rtems_region_return_segment - return segment to region 2 - 0x00000f70
>TA1 - rtems_task_delete - delete TA3
><pause>
... more output after this is correct. sp16.scn has TA3 getting its
segment and waitng for another before being deleted.
