global contructors
Thu Aug 24 00:28:20 UTC 2006
Philippe Simons wrote:
> I'm close to get global construcors working on ARM.
> my .init/.fini and .ctors/.dtors sections are build correctly
> I made some test to force the call to _init() in the Init task, and it
> seems to works.
> but where should i define the __USE_INIT_FINI__ to let _Thread_Handler
> call _init()?
> i tried to add it in the bsp_specs using: %(old_cpp) %{qrtems:
> -D__USE_INIT_FINI__ }
> but it doesnt seems to change anything to _Thread_Handler
> any tips on this?
You need to build the tools with the correct setup:
[cjohns at moa rtemsrpms]$ which i386-rtems4.7-gcc
/opt/rtems-4.7/bin/i386-rtems4.7-gcc
[cjohns at moa rtemsrpms]$ i386-rtems4.7-gcc -dM -E - </dev/null | grep
__USE_INIT_FINI__
#define __USE_INIT_FINI__ 1
[cjohns at moa rtemsrpms]$ arm-rtems4.7-gcc -dM -E - </dev/null | grep
__USE_INIT_FINI__
Looking at the source for the rtems-4.7 tool set:
[chrisjohns at england config]$ pwd
/home/chrisjohns/rtems/4.7/packages/BUILD/custom-arm-rtems4.7-gcc-4.1.1/gcc-4.1.1/gcc/config
[chrisjohns at england config]$ grep -r __USE_INIT_FINI__ arm
[chrisjohns at england config]$ grep -r __USE_INIT_FINI__ m68k
m68k/rtemself.h:        builtin_define ("__USE_INIT_FINI__");   \
I did notice the arm does have __USES_INITFINI__ defined but this is
only target in gcc to have this.
Should the arm have __USE_INIT_FINI__ defined or should RTEMS handle
__USES_INITFINI__ or is it safe to assume __ELF__ means __USE_INIT_FINI__ ?
Regards
