Creation of initial task fails with RTEMS_UNSATISFIED
Ingolf Steinbach Ingolf.Steinbach at jena-optronik.de
Thu Aug 24 12:14:08 UTC 2006
Chris Johns wrote:
> You should increase the number of tasks. Driver can contain tasks and
> this would consume the single task resource you have allocated.
Thank you.
Although the problem does no longer show up (with
CONFIGURE_MAXIMUM_TASKS set to 2), I am a bit irritated:
a) I'd expect to see RTEMS_TOO_MANY rather than
    RTEMS_UNSATISFIED
b) a breakpoint in rtems_task_create() is reached only once.
Apart from that, I thought that the CONFIGURE_* values
represent the amount of resources required by the application
itself, not including any resources needed implicitly by
RTEMS. For instance, it appears that for each file descriptor,
a semaphore is created implicitly. This works even if I
set CONFIGURE_MAXIMUM_SEMAPHORES to 0.
Kind regards
     Ingolf
Ingolf Steinbach                       Jena-Optronik GmbH
ingolf.steinbach at jena-optronik.de       ++49 3641 200-147
PGP: 0x7B3B5661  213C 828E 0C92 16B5  05D0 4D5B A324 EC04
