global contructors
Thu Aug 24 22:08:05 UTC 2006
Philippe Simons wrote:
> So i need to add "builtin_define ("__USE_INIT_FINI__");" to
> arm/rtemself.h or add a #ifdef __ELF__ to _Thread_Handler?
We are the only OS putting __USE_INIT_FINI__ into gcc so I have to
wonder why we do this. There is no code in gcc or newlib that depends on it.
There was a time when we supported m68k-coff and m68k-elf and this was
the solution. The coff and elf systems handled static constructors
differently.
The main point behind the __ELF__ comment was based on all our targets
now supporting ELF. Looking more I see we have a couple of targets such
as H8300 and SH that do not have __USE_INIT_FINI__. GCC has a comment
about some ELF targets "use crtstuff.c to provide __CTOR_LIST__" so it
may not be completely safe. The H8300 and SH may be such targets.
Another solution is to add __USE_INIT_FINI__ to the RTEMS cpu header
file and remove it from gcc.
Ralf maintains the tools and it is his call on what to do.
Regards
