h8300 16-bit warnings
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Aug 28 19:22:12 UTC 2006
Hi,
I am going on a pre-branching warning hunt and Ralf suggested
going over the h8300-multilib set of warnings. I am collecting
notes on what I can see a fix for but don't precisely know the
right answer. Many are very simple due to printf format specifications
or not using the correct and already existing type.
+ sys/ioccomm.h 16-bit clean _IOxx definitions
+ what type should you use when casting a pointer to an
integer?
+ sys/mbuf.h M_COPYALL needs to have a 16-bit clean definition.
Any thoughts on the above?
I need to doublecheck what I have done before I comment what I have.
I don't want to accidentally make it worse. :)
--joel
