Debug Version of Rtems 4.6.99.3
Till Straumann strauman at slac.stanford.edu
Thu Aug 31 17:20:21 UTC 2006
I don't know what 'proper' method is but I found that
I can build rtems with '-g' by adding
'RTEMS_CFLAGS=-g' to the commandline when configuring
configure 'RTEMS_CFLAGS=-g' <more options>
This doesn't switch off optimization, though.
HTH
-- Till
John Wood wrote:
>I am trying to build rtems with debug info.  I tried several of the
>methods
>in the archives but haven't had much luck.
>Building the hello world example with make debug fails since the debug
>versions of libraries are not there.
>I am building with --enable-rtems-debug.  I cant seem to do a make debug
>in the rtems build tree. I am building my own BSP with 4.6.99.3
>What am I missing?
>Thanks,
>John
