RES: RTEMS optimization level
Fabrício de Novaes Kucinskis fabricio at dea.inpe.br
Thu Aug 3 16:43:08 UTC 2006
Oops, I found it.
If someone else has the same doubt, the file
[rtems-path]/custom/make/erc32.cfg contains the optimization flag
CFLAGS_OPTIMIZE_V.
Best Regards,
Fabrício.
-----Mensagem original-----
De: Fabrício de Novaes Kucinskis [mailto:fabricio at dea.inpe.br]
Enviada em: quinta-feira, 3 de agosto de 2006 11:50
Para: RTEMS - Mailing List
Assunto: RTEMS optimization level
Hello,
I'm using C to create RTEMS applications (SPARC/ERC32 BSP), and I want to
try RTEMS at different levels of compiler optimization, but I'm a little bit
lost with so many configuration files and makefiles.
So, where and how should I change the RTEMS optimization level?
Thanks in advance!
Fabrício de Novaes Kucinskis - DEA / INPE
Grupo de Supervisão de Bordo - SUBORD
Divisão de Eletrônica Aeroespacial
Instituto Nacional de Pesquisas Espaciais
