Comparision RTEMS <-> eCos
Ole Hansen
Ole at danelec.dk
Thu Aug 10 22:57:39 UTC 2006
Hello Evgeny Belyanco
We have successfully been using RTEMS for AT91RM9200 on
our 'own' boards for more than a year now.
The best way to debug your AT91RM9200 is via JTAG and BDI2000 - debugger.
BDI2000 will also allow you to program your FLASH.
We are using UBOOT for loading RTEMS via DHCP/TFTPBOOT from a Linux-host.
regards
ole at danelec.dk
> -----Original Message-----
> From: Evgeny Belyanco [mailto:esp1 at kbkcc.ru]
> Sent: 11. august 2006 00:40
> To: Joel Sherrill
> Cc: rtems-users at rtems.com
> Subject: Re[2]: Comparision RTEMS <-> eCos
> Friday, August 11, 2006, 2:10:13 AM, you wrote:
> JS> What features are you looking for?
> JS> Ask specific questions and people can given answers.
> My target now is AT91RM9200, and I am planning to use MCF5208, when
> they will be available (I hope I will be able to modify existing
> MPC52xx ports....).
> My interests are:
> * which "real time" is more real - RTEMS or eCos
> - in case of using Pthreads and Native API
> - time to ISR reaction in case of heavy loaded system
> * what IP stack has more performance - RTEMS or eCos
> - Ethernet
> * wich driver model - RTEMS or eCos - is more friendly to programmer,
> and easy in development
> - comparison of DMA drivers - performance?
> * GDB remote debugging over Ethernet - flexibility & stability?
> * Ability to porting Unix software to OS - as far, as I understand,
> RTEMS is mach more POSIX, than eCos (of course with some excerptions)
> http://www.ocera.org/archive/deliverables/ms1-month6/WP1/D1.1.
html#AEN2041
Is AT91RM9200 RTEMS port allow GDB remote debugging over Ethernet?
Evgeny Belyanko
* E-mail: ea at kbkcc.ru
