FastDB under RTEMS
Evgeny Belyanco esp1 at kbkcc.ru
Mon Aug 14 11:06:28 UTC 2006
Monday, August 14, 2006, 3:03:09 PM, you wrote:
>> www.fastdb.org
>> www.garret.ru/~knizhnik/fastdb.html
JS> Are there any references to RTEMS in the sources?
No.
JS> I repeat what with POSIX enabled in RTEMS, it wasn't particularly
JS> hard to get to build and run the demo.
Ok.
JS> And RTEMS doesn't support virtual memory so mmap is not supported.
JS> The IMFS is an in-memory filesystem.  If you use that, it is effectively
JS> mapped.
Thank you for answers!
Evgeny Belyanko
* E-mail: ea at kbkcc.ru
