sparc stack and heap
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Aug 21 14:34:40 UTC 2006
Yacine EL KOLLI wrote:
> Hello,
> AFAIK, CONFIGURE_INIT_STACK_SIZE does only change the stack size of
> the init task.
> For pthread this is defined by default in:
> cpukit/posix /include/rtems/posix/pthread.h at line 26:
> #define PTHREAD_MINIMUM_STACK_SIZE (STACK_MINIMUM_SIZE * 2)
> May be the proper way to modify the pthread default stack size is to
> specify the stack size when creating the thread or to modify the
> global variable _POSIX_Threads_Default_attributes ?
Don't change the default attributes. There is a way to use an explicit
set of pthread attributes and
the stack size is one of those. You will need to use pthread_attr_init and
pthread_attr_setstacksize. Then pass the attributes to pthread_create.
Sorry if this is confusing. I just implemented the API, I didn't design
it. :)
--joel
> Also you can enable the stack checker (#define STACK_CHECKER_ON in
> your appllication header)
> Hope this help
> Yacine.
> Marek Prochazka wrote:
>> Hello,
>> in my application on Leon2, I configure RTEMS to have
>> CONFIGURE_INIT_STACK_SIZE (20 * RTEMS_MINIMUM_STACK_SIZE)
>> This gives 81920 bytes for a single task stack. However, if I print
>> addresses of two variables allocated on stack in two different POSIX
>> threads (I assume each POSIX thread uses a single RTEMS task), I get
>> 0x4ffa5e84 and 0x4ffa38c4. This gives only 0x25c0 (9664) bytes
>> difference, which does not seem right. Am I missing something?
>> We are apparently having problems with not properly controlling stack
>> size hence in case of more allocation on the stack we perhaps
>> experience an overflow (random crashes, the fewer automatic
>> variables, the later a crash occurs). Any hints please? Any
>> diagnostic tools available?
>> Thanks,
>> Marek Prochazka
>>> -----Original Message-----
>>> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com] Sent: 25 July
>>> 2006 15:11
>>> To: Aleix Conchillo Flaqué
>>> Cc: Chris Johns; rtems-users at rtems.com
>>> Subject: Re: sparc stack and heap
>>> Aleix Conchillo Flaqué wrote:
>>>> Thanks for the answer Chris.
>>>> I'll need to modify some things from the ERC32 bsp, because
>>> I need to
>>>> keep some data into RAM between reboots, so I'll have to play with
>>>> heap and workspace addresses.
>>> The simplest think to do would be to edit the linkcmds and reserve
>>> an area after the BSS. If you
>>> move the "end" symbols to after your reserved block, then it will
>>> just be ignored by the BSP
>>> when it is carving memory.
>>> You could do this in an application specific linkcmds and add
>>> -qnolinkcmds -T myLinkcmds
>>> to the gcc command that links your application. It would avoid
>>> otherwise changing the
>>> BSP as installed by RTEMS.
>>> --joel
>>>> Regards,
>>>> aleix
>>>>>> I'll answer my self, task stacks are allocated in the heap. Right?
>>>>> No the workspace.
>>>>> You need to decided now to the split the memory between the
>>>>> workspace and the heap. The typical way is to place the
>>> workspace at
>>>>> the top and the heap between the end of .bss and the start of the
>>>>> workspace.
>>>>> Regards
>>>>> Chris
