libchip/m48t08 driver
Till Straumann
strauman at slac.stanford.edu
Tue Aug 22 01:15:05 UTC 2006
On Mon, 2006-08-21 at 17:58 -0500, Joel Sherrill wrote:
> Till Straumann wrote:
> > I thought about merging some extended features
> > I implemented in BSP specific drivers for m48txx
> > series RTC chips into the generic libchip version.
> > Looking at that one (i.e., libchip/rtc/m48t08.c),
> > I found that it is not thread safe.
> > RFC: Would it be acceptable for this
> > driver to use a mutex?
> Before doing that .. Does it do things that would be too inappropriate
> for simply
> disabling preemption or interrupts? Disabling preemption for short
> periods of
> time is no worse on latency than calling a pair of directives.
Yeah - I guess that could be done. It's ~ 10 (simple) subroutine calls
(not inlined) for register access where each access takes ~100ns (bus
cycle for accessing the device), so the optimal solution might
depend on architecture.
T.
> Otherwise, a mutex is OK.
> > - T.
