Networking support for Linux target
Navin Garg
ngarg at mykotronx.com
Tue Aug 22 15:36:46 UTC 2006
Ali,
I'm trying to build on a Pentium PC running Linux, which does support
networking.
So, what should my "configure" command be?
Thanks,
Navin
-----Original Message-----
From: Ali Asgar Nasir [mailto:aliasgar.nasir at patni.com]
Sent: Tuesday, August 22, 2006 6:03 AM
To: Navin Garg; rtems-users at rtems.com
Subject: Re: Networking support for Linux target
Hi,
what is ur target processor? Does it support networking?
In the command of configure what follows the command
"-enable-rtemsbsp="?
What do mean by linux target? Ur target should be a processor or a
processor
family and not an OS like linux.
Regards
Ali
----- Original Message -----
To: <rtems-users at rtems.com>
Sent: Monday, August 21, 2006 8:57 PM
Subject: Networking support for Linux target
> Hi,
> I built RTEMS under linux and want to use linux as the target. The
build
> appeared to succeed however, there is no networking support even
though
> I had specified "--enable-networking".
> I used the following configure command:
> ./configure --disable-itron --enable-networking -enable-rtemsbsp=
> --enable-tests --enable-docs --disable-cxx
> Can I not include networking support for a linux target? Or, is there
> something wrong with this configure command?
> Any help would be greatly appreciated.
> Thanks,
> Navin
http://www.patni.com
World-Wide Partnerships. World-Class Solutions.
_____________________________________________________________________
This e-mail message may contain proprietary, confidential or legally
privileged information for the sole use of the person or entity to
whom this message was originally addressed. Any review, e-transmission
dissemination or other use of or taking of any action in reliance upon
this information by persons or entities other than the intended
recipient is prohibited. If you have received this e-mail in error
kindly delete this e-mail from your records. If it appears that this
mail has been forwarded to you without proper authority, please notify
us immediately at netadmin at patni.com and delete this mail.
