Networking support for Linux target
Daron Chabot
daron at nucleus.usask.ca
Wed Aug 23 14:18:51 UTC 2006
Ali Asgar Nasir wrote:
> Navin,
> The confiure command should contain the target processor on which u r
> going to port the OS. The Pentium machine which u r using is the host
> machine...What is your final target on which u want to port the OS? If
> it is the same home machine(Pentium), then the configure command
> should have the field "-enable-rtemsbsp = i386-rtems".
I think perhaps you mean the configure line should contain:
--target=i386-rtems --enable-rtemsbsp=pc386
-- dc
