_Internal_error_Occurred from rtems_semaphore_obtain in rtems_termios_write
Kenneth J. Peters
Kenneth.J.Peters at jpl.nasa.gov
Wed Aug 30 20:58:35 UTC 2006
Of course, as soon as I sent to the list, I found more info. I see
now that the magic "18" corresponds to RTEMS_CALLED_FROM_ISR from
cpukit/rtems/include/rtems/rtems/status.h
and from doc/porting/interrupts.t I see that
_Thread_Dispatch_disable_level is basically saying I'm in a trap
somewhere.
It still seems to me that _CORE_mutex_Seize should use a defined
value, either from the RTEMS status values or from the internal
errors list. Those two lists of values do not agree at all entries.
Ken
>I'm getting _Internal_error_Occurred called from
>rtems_semaphore_obtain in rtems_termios_write.
>Sparc erc32-based BSP on custom hardware.
>Two issues:
>1. The _Internal_error_Occurred call is actually in
>cpukit/score/include/rtems/score/coremutex.h
>and is just called with a hardcoded number, not an
>Internal_errors_Core_list enum item from
>cpukit/score/include/rtems/score/interr.h
>>#define _CORE_mutex_Seize( \
>> _the_mutex, _id, _wait, _timeout, _level ) \
>> do { \
>> if ( _Thread_Dispatch_disable_level \
>> && (_wait) \
>> && (_System_state_Get() >= SYSTEM_STATE_BEGIN_MULTITASKING ) \
>> _Internal_error_Occurred( \
>> INTERNAL_ERROR_CORE, \
>> FALSE, \
>> 18 /* called from wrong environment */); \
>Seems like this error code should be in the
>Internal_errors_Core_list enum . I don't know if there are any other
>hardcoded error values elsewhere.
>2. I have not traced all through my code yet, or created a simple
>example. It could be that I am just doing something stupid like
>accidentally trying to print in a trap handler. However, if some
>kernel expert can explain a little about
>_Thread_Dispatch_disable_level, that might help me figure out what's
>going on. I am in multitasking when the error occurs, and the obtain
>call is with RTEMS_WAIT, so those make general sense to me.
>Ken Peters
>Ken.Peters at jpl.nasa.gov
