Problem report: Struct aliasing problem causes Thread_Ready_Chain corruption in 4.6.99.3
Aaron J. Grier aaron at frye.com
Fri Dec 8 01:26:10 UTC 2006
On Thu, Dec 07, 2006 at 05:13:42PM -0800, Till Straumann wrote:
> Unless you can 'prove' that RTEMS is in compliance with the standard
> (by carefully revising the source) we should build it with
> -fno-strict-aliasing.
I'll ask the obvious question: "does RTEMS wish to be C99 compliant?"
-std=c89
-std=gnu89
-std=iso9899:199409
take your pick.  (gnu89 is the default for 3.x)
  Aaron J. Grier  |   Frye Electronics, Tigard, OR   |  aaron at frye.com
