Xilinx IP core drivers for RTEMS- diff attached
Robert S. Grimes rsg at alum.mit.edu
Thu Dec 21 15:43:37 UTC 2006
Oh, the final error is in the
<BUILDROOT>/powerpc-rtems/c/gen405/testsuites/samples/hello example
program build.
Also, in the "First Attempt", the path should be
<BUILDROOT>/powerpc-rtems/gen405/lib/include/libchip
Robert S. Grimes wrote:
> Okay, I've got major egg on my face!  The "xilemac.c and xilemac.h are
> identical" comment is false!  Red Herring!  My screw-up!
> This morning, I decided to start over, and see if I can prove or
> disprove it.  So I started with a clean un-tar, applied the patch, then
> looked at xilemac.h - lo and behold, it is now a real header file!  I
> still can't quite get it to build, though.  Here is what I've found so
> far...
> First Attempt:
>     make all
>       - fails during compile due to missing xilemac.h file
>     Fix:  cp <SOURCEROOT>/c/src/libchip/network/xilemac.h
>     <BUILDROOT>/gen405/lib/include/libchip
> Second Attempt:
>     make all
>       - fails during compile due to missing opbintctrl.h
>     Fix: cp
>     <SOURCEROOT>/c/src/lib/libbsp/powerpc/gen405/include/opbintctrl.h
> Third Attempt
>     make all
>       - fails during link due to error:
>     gen405/lib/librtemsbsp.a(startup.rel): In function `bsp_predriver_hook':
>     c/src/lib/libbsp/powerpc/gen405/startup/bspstart.c:107: undefined
>     reference to `opb_intc_init'
> I haven't yet resolved the third problem, but I have narrowed it down a
> wee bit.  Seems
> <ROOT>/c/src/lib/libbsp/powerpc/gen405/opbintctrl/opbintctrl.c is not
> being compiled or included in the link.
> I'll keep you informed, and once again, SORRY!!!
> -Bob
>> Wow!  I don't know what happened, if it was the atuoconf/automake stuff
>> or not, but I just realized in the source tree after patching, the files
>> xilemac.c and xilemac.h are identical; specifically, they both contain
>> what should be the .c contents!  This explains why there is the #include
>> directive!  It may be my error, and I have to leave now so I can't
>> confirm one way or the other, but my guess is that you might be sending
>> xilemac.c to both the .c and .h files during configure.  Of course, it
>> may be I don't know what I'm talking about...
>> More tomorrow...
>> -Bob
>> gregory.menke at gsfc.nasa.gov wrote:
>>> Hi Bob,
>>> There is only one xilemac.h, and it should be in libchip.
>>> gen405/include/bsp.h is supposed to include libchip/xilemac.h, so it can
>>> obtain driver definitions.  I just checked the diff and it looks like I
>>> screwed it up- I see the extra include as you say, but it does not exist
>>> in my source.  Beats me how I messed it up, but there you go...
>>> With the gen405 in its present setup, I think xilemac would be better
>>> located in the bsp than in libchip.  If/when a virtex bsp shows up, then
>>> xilemac could be copied into libchip- leaving the current version in
>>> gen405 sort of like how the pc386 bsp has its own network drivers.
>>> If/when gen405 moves to new_exceptions then maybe it could abandon its
>>> internal xilemac in favor of the libchip version.
>>> Given the above, I'd like to regenerate the diff with xilemac moved back
>>> into the gen405 bsp, which makes sense given the old_exceptions and the
>>> assumptions about the driver that the bsp makes.  I'll try to get a new
>>> patch out in a day or so, and please accept my apologies for the broken
>>> diffs...
>>> Regards,
>>> Greg
>>> Robert S. Grimes writes:
>>>  > Yes,
>>>  > It looks like $SOURCEDIR/c/src/libchip/network/xilemac.h (only xilemac.h
>>>  > I was able to find in source tree) is not making it into
>>>  > $BUILDIDR/powerpc-rtems/gen405/lib/include/libchip.
>>>  > I attempted to fix that by copying the file.  However, when I did that,
>>>  > I got a problem about infinite include nesting; seems the file was
>>>  > including itself?  Perhaps I am confused, but there is an include
>>>  > directive in xilemac.h like this
>>>  > #include <libchip/xilemac.h>
>>>  > If I comment that out, the infinite nesting problem goes away, but is
>>>  > replaced by these
>>>  > In file included from ../../../../.././gen405/lib/include/bsp.h:73,
>>>  >                  from
>>>  > ../../../../../../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc/old-exceptions/cpu.c:31:
>>>  > ../../../../.././gen405/lib/include/libchip/xilemac.h:234: error:
>>>  > 'NUM_XILEMAC_UNITS' undeclared here (not in a function)
>>>  > ../../../../.././gen405/lib/include/libchip/xilemac.h: In function
>>>  > 'xilFifoRead32':
>>>  > ../../../../.././gen405/lib/include/libchip/xilemac.h:270: error:
>>>  > 'XEM_PFIFO_RXDATA_OFFSET' undeclared (first use in this function)
>>>  > ../../../../.././gen405/lib/include/libchip/xilemac.h:270: error: (Each
>>>  > undeclared identifier is reported only once
>>>  > ./../../../.././gen405/lib/include/libchip/xilemac.h:270: error: for
>>>  > each function it appears in.)
>>>  > 'xilFifoWrite32':
>>>  > ../../../../.././gen405/lib/include/libchip/xilemac.h:309: error:
>>>  > 'XEM_PFIFO_TXREG_OFFSET' undeclared (first use in this function)
>>>  > ../../../../.././gen405/lib/include/libchip/xilemac.h:318: error:
>>>  > 'DRIVER_PREFIX' undeclared (first use in this function)
>>>  > ../../../../.././gen405/lib/include/libchip/xilemac.h:327: error:
>>>  > 'XEM_PFIFO_TXDATA_OFFSET' undeclared (first use in this function)
>>>  > 'xilGetWrFifo32VacancyBytes':
>>>  > ../../../../.././gen405/lib/include/libchip/xilemac.h:363: error:
>>>  > 'xilFifoRead64':
>>>  > ../../../../.././gen405/lib/include/libchip/xilemac.h:385: error:
>>>  > 'xilFifoWrite64':
>>>  > ../../../../.././gen405/lib/include/libchip/xilemac.h:440: error:
>>>  > ../../../../.././gen405/lib/include/libchip/xilemac.h:445: error:
>>>  > ../../../../.././gen405/lib/include/libchip/xilemac.h:452: error:
>>>  > 'xilGetWrFifo64VacancyBytes':
>>>  > ../../../../.././gen405/lib/include/libchip/xilemac.h:507: error:
>>>  > 'xilGetWrFifoVacancyBytes':
>>>  > ../../../../.././gen405/lib/include/libchip/xilemac.h:533: error:
>>>  > 'xilEmacStop':
>>>  > ./../../../.././gen405/lib/include/libchip/xilemac.h:548: error:
>>>  > dereferencing pointer to incomplete type
>>>  > ../../../../.././gen405/lib/include/libchip/xilemac.h:551: error:
>>>  > 'XEM_ECR_OFFSET' undeclared (first use in this function)
>>>  > ../../../../.././gen405/lib/include/libchip/xilemac.h:555: error:
>>>  > ../../../../.././gen405/lib/include/libchip/xilemac.h:559: error:
>>>  > and so on, especially the deref pointer errors.
>>>  > Seems something else is missing wrt the Xilinx definitions...
>>>  > Thanks,
>>>  > -Bob
>>>  > > Hi Robert,
>>>  > > Its likely something missing from the patch since I had a strip out a
>>>  > > lot of test things from the diff.  I'll have a look at get back to you.
>>>  > > OTOH I continue to have problems with automake/autoconf occasionally
>>>  > > generating makefiles that need editing because its unclear which
>>>  > > versions work and which won't and RTEMS stays so close to the
>>>  > > toolchain's bleeding edge that its hard to tell.  So there is some
>>>  > > possiblity that automake/autoconf issues could be causing trouble.
>>>  > > Greg
>>>  > >  > Hi Greg,
>>>  > >  > I attempt to build using your patches on a clean install of 4.6.99.3,
>>>  > >  > and I get this error:
>>>  > >  >     Making all in powerpc
>>>  > >  >     make[5]: Entering directory
>>>  > >  >     `/cygdrive/c/Home/ll/etill/rtems-4.6.99.3/tools/b-rtems-4.6.99.3/powerpc-rtems/c/gen405/lib/
>>>  > >  >     libcpu/powerpc'
>>>  > >  >     if powerpc-rtems-gcc --pipe -B../../../../.././lib/
>>>  > >  >     -B../../../../.././gen405/lib/ -specs bsp_specs -qrtems -DPACKAGE_NA
>>>  > >  >     ME=\"rtems-c-src-lib-libcpu-powerpc\"
>>>  > >  >     -DPACKAGE_TARNAME=\"rtems-c-src-lib-libcpu-powerpc\"
>>>  > >  >     -DPACKAGE_VERSION=\"4.6.99.3\
>>>  > >  >     " -DPACKAGE_STRING=\"rtems-c-src-lib-libcpu-powerpc\ 4.6.99.3\"
>>>  > >  >     -DPACKAGE_BUGREPORT=\"rtems-bugs at rtems.com\"  -I. -I../.
>>>  > >  >     ./../../../../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc  -isystem
>>>  > >  >     ../../../../.././gen405/lib/include -I../../../../../
>>>  > >  >     ../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc/old-exceptions  -Wall
>>>  > >  >     -mcpu=403 -D_OLD_EXCEPTIONS -Dppc405 -O4 -fno-keep-i
>>>  > >  >     nline-functions -g -MT
>>>  > >  >     old-exceptions/old_exceptions_rtems_cpu_rel-cpu.o -MD -MP -MF
>>>  > >  >     "old-exceptions/.deps/old_exception
>>>  > >  >     s_rtems_cpu_rel-cpu.Tpo" -c -o
>>>  > >  >     old-exceptions/old_exceptions_rtems_cpu_rel-cpu.o `test -f
>>>  > >  >     'old-exceptions/cpu.c' || echo
>>>  > >  >      '../../../../../../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc/'`old-exceptions/cpu.c;
>>>  > >  >     then mv -f
>>>  > >  >     "old-exceptions/.deps/old_exceptions_rtems_cpu_rel-cpu.Tpo"
>>>  > >  >     l-cpu.Po"; else rm -f
>>>  > >  >     "old-exceptions/.deps/old_exceptions_rtems_cpu_rel-cpu.Tpo"; exit 1; fi
>>>  > >  >     ../../../../.././gen405/lib/include/bsp.h:73:29: error:
>>>  > >  >     libchip/xilemac.h: No such file or directory
>>>  > >  >     make[5]: *** [old-exceptions/old_exceptions_rtems_cpu_rel-cpu.o] Error 1
>>>  > >  >     make[5]: Leaving directory
>>>  > >  >     `/cygdrive/c/Home/ll/etill/rtems-4.6.99.3/tools/b-rtems-4.6.99.3/powerpc-rtems/c/gen405/lib/l
>>>  > >  >     ibcpu/powerpc'
>>>  > >  > The "xilemac.h" file certainly does exist!  It seems there's an include
>>>  > >  > path problem.  I'm going to try and track it down, but I thought you might:
>>>  > >  >   - know what I did wrong (if it's my mistake), or
>>>  > >  >   - want to know (if it's a patch problem).
>>>  > >  > I will let you know what I find on my end.
>>>  > >  > Thanks!
>>>  > >  > -Bob
>>>  > >  > > Hi,
>>>  > >  > > I finally got back to some long-needed config management on the gen405
>>>  > >  > > bsp.  I assembled the diffs against 4.6.99.3, the file is attached for
>>>  > >  > > review.
>>>  > >  > > I hesitate to just check them in as some of the changes related to
>>>  > >  > > uarts, fpu and memory map are highly idiosyncratic and I don't want to
>>>  > >  > > mess up other people's work.  I think a compromise patch might make the
>>>  > >  > > most sense, where I set up a diff that preserves the general character
>>>  > >  > > of the bsp; base addresses, etc.. but gets in the updated drivers.
>>>  > >  > > Our bsp was peculiar in that the 405 units have 4 uarts and no fpu at
>>>  > >  > > all, meaning, the entire toolchain has to be compiled with -msoft-float
>>>  > >  > > to ensure nothing at all in newlib or above uses fp registers- the
>>>  > >  > > va_args are problematic since the ppc ABI allows fpu registers to be
>>>  > >  > > used when handing variable arguments.  I think it is this issue that
>>>  > >  > > generally forces all PPC tasks to be floating point- its quite an
>>>  > >  > > annoying architectural property.
>>>  > >  > > So I'd like to propose that folks interested in the Virtex 4 gen405 bsp
>>>  > >  > > family have a look at the diffs and respond with issues & changes and
>>>  > >  > > hopefully I can commit something that doesn't cause too much trouble.
>>>  > >  > > If folks' email systems won't pass the attachment, then please email me
>>>  > >  > > and I'll resend directly.
>>>  > >  > > Thanks,
>>>  > >  > > Greg
>>>  > >  > > _______________________________________________
>>>  > >  > > rtems-users mailing list
>>>  > >  > > rtems-users at rtems.com
>>>  > >  > > http://rtems.rtems.org/mailman/listinfo/rtems-users
