Re-2: Buildung Tools for m68k-RTEMS 4.6.99.3 on Cygwin Host
Thu Dec 21 22:39:52 UTC 2006
frank.ueberschar at dsa-volgmann.de wrote:
> Yes. I had to change /etc/fstab manually because I installed
> it on a different directory due to space requirements.
Did this installer get the path wrong in the /etc/fstab ?
> (However, an 's' was to append on .../rtems/4.7/build/rpm's' to get
> this installation working)
Ok. I will update the documentation.
> (At this point of my experience I've installed cygwin and MinGW
> on my PC - using with different serch paths. Bootstrapping on cygwin
> buildin on minGW.)
If you have this working and you can manage both I see no problem.
Regards
