Problem report: Struct aliasing problem causes Thread_Ready_Chain corruption in 4.6.99.3
Thomas Doerfler
Thomas.Doerfler at embedded-brains.de
Mon Dec 4 20:16:24 UTC 2006
Kim,
when I look into the current RTEMS networking stack, you are right.
There we find:
struct sockaddr {
unsigned char sa_len; /* total length */
sa_family_t sa_family; /* address family */
char sa_data[14]; /* actually longer; address value */
struct sockaddr_in {
uint8_t sin_len;
sa_family_t sin_family;
in_port_t sin_port;
struct in_addr sin_addr;
char sin_zero[8];
sockaddr_in is sometimes overlayed by sockaddr, which is definitively
non-aliased.
IMHO we might come over this, by defining
struct sockaddr sa;
in_port_t sin_port;
char sin_zero[8];
But then, the semantics to access elements in the "general" header would
change, which would break a huge amount of code dealing with sockets.
And would make them non-standard, I would guess.
You may come around this when you are writing application code, because
then you will work with ONE type of socket at a given piece of code, but
I am not sure how we can get over this without (partially) disabling the
aliasing optimizations...
Any hints?
wkr,
Thomas.
Kim Barrett schrieb:
> At 8:30 AM -0800 12/4/06, Till Straumann wrote:
>> While the optimization is optional, programs that violate the
>> aliasing rule are unfortunately not C99 compliant - the
>> standard does *not* declare this rule optional, unfortunately.
> De-lurking briefly, in this very interesting discussion, to ask:
> Am I confused, or is POSIX riddled with strict-aliasing violations?
> I'm thinking, for example, of the struct sockaddr variants, where
> one allocates space for a sockaddr_in or sockaddr_un or whatever,
> but often passes it around as a (cast to) sockaddr*. While sockaddr
> has a "common initial sequence" (C99 6.5.2.3 para5) with sockaddr_in
> &etc, there is nothing I can find that would indicate that they are
> "compatible types" (C99 6.2.7 &etc), and 6.7.7 example 2 seems to
> explicitly indicate that they are not.
> And since the aliasing rules are written in terms of "compatible
> types", this makes me suspicious.
> rtems-users mailing list
> rtems-users at rtems.com
embedded brains GmbH
Thomas Doerfler Obere Lagerstr. 30
D-82178 Puchheim Germany
Tel. : +49-89-18 90 80 79-2
Fax : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
