_Region_Get and strict aliasing
Steven Johnson
sjohnson at sakuraindustries.com
Wed Dec 20 02:29:57 UTC 2006
Lets see if I follow your logic,
You say, because the pointer to the object returned by _Region_Get may
have been at its creation a Region_Control structure, then the casting
doesn't change that effective type, and so the pointer to the object can
be cast to anything (provided that the cast pointer is not accessed) and
when it is cast back then it can still be accessed as a Region_Control
structure. It would just be an invalid alias to access it through one
of it's type cast intermediaries.
Is this the basis of your argument that this is not an illegal alias?
So the following applies:
int a;
long *b = (long*)&a;
short *c = (shortc*)b;
void *d = (void*)c;
int *e = (int*)d;
long* f = (long*)d;
In the above ... means a lot of code, function calls, indirection, etc,
that mean the true effective type of the object previously cast can not
be determined by the compiler.
One can access *e to get at 'a', but any use of *c, *d or *f to get at
any part of the object 'a' would be an invalid alias. Even if their was
no possible way for the compiler to determine that the object *c, *d and
*f points to has an effective type of int.
Steven J
