Xilinx IP core drivers for RTEMS- diff attached
Robert S. Grimes
rsg at alum.mit.edu
Wed Dec 20 15:10:27 UTC 2006
Hi Greg,
I attempt to build using your patches on a clean install of 4.6.99.3,
and I get this error:
Making all in powerpc
make[5]: Entering directory
`/cygdrive/c/Home/ll/etill/rtems-4.6.99.3/tools/b-rtems-4.6.99.3/powerpc-rtems/c/gen405/lib/
libcpu/powerpc'
if powerpc-rtems-gcc --pipe -B../../../../.././lib/
-B../../../../.././gen405/lib/ -specs bsp_specs -qrtems -DPACKAGE_NA
ME=\"rtems-c-src-lib-libcpu-powerpc\"
-DPACKAGE_TARNAME=\"rtems-c-src-lib-libcpu-powerpc\"
-DPACKAGE_VERSION=\"4.6.99.3\
" -DPACKAGE_STRING=\"rtems-c-src-lib-libcpu-powerpc\ 4.6.99.3\"
-DPACKAGE_BUGREPORT=\"rtems-bugs at rtems.com\" -I. -I../.
./../../../../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc -isystem
../../../../.././gen405/lib/include -I../../../../../
../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc/old-exceptions -Wall
-mcpu=403 -D_OLD_EXCEPTIONS -Dppc405 -O4 -fno-keep-i
nline-functions -g -MT
old-exceptions/old_exceptions_rtems_cpu_rel-cpu.o -MD -MP -MF
"old-exceptions/.deps/old_exception
s_rtems_cpu_rel-cpu.Tpo" -c -o
old-exceptions/old_exceptions_rtems_cpu_rel-cpu.o `test -f
'old-exceptions/cpu.c' || echo
'../../../../../../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc/'`old-exceptions/cpu.c;
then mv -f
"old-exceptions/.deps/old_exceptions_rtems_cpu_rel-cpu.Tpo"
l-cpu.Po"; else rm -f
"old-exceptions/.deps/old_exceptions_rtems_cpu_rel-cpu.Tpo"; exit 1; fi
In file included from
../../../../../../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc/old-exceptions/cpu.c:31:
../../../../.././gen405/lib/include/bsp.h:73:29: error:
libchip/xilemac.h: No such file or directory
make[5]: *** [old-exceptions/old_exceptions_rtems_cpu_rel-cpu.o] Error 1
make[5]: Leaving directory
`/cygdrive/c/Home/ll/etill/rtems-4.6.99.3/tools/b-rtems-4.6.99.3/powerpc-rtems/c/gen405/lib/l
ibcpu/powerpc'
The "xilemac.h" file certainly does exist! It seems there's an include
path problem. I'm going to try and track it down, but I thought you might:
- know what I did wrong (if it's my mistake), or
- want to know (if it's a patch problem).
I will let you know what I find on my end.
Thanks!
-Bob
gregory.menke at gsfc.nasa.gov wrote:
> Hi,
> I finally got back to some long-needed config management on the gen405
> bsp. I assembled the diffs against 4.6.99.3, the file is attached for
> review.
> I hesitate to just check them in as some of the changes related to
> uarts, fpu and memory map are highly idiosyncratic and I don't want to
> mess up other people's work. I think a compromise patch might make the
> most sense, where I set up a diff that preserves the general character
> of the bsp; base addresses, etc.. but gets in the updated drivers.
> Our bsp was peculiar in that the 405 units have 4 uarts and no fpu at
> all, meaning, the entire toolchain has to be compiled with -msoft-float
> to ensure nothing at all in newlib or above uses fp registers- the
> va_args are problematic since the ppc ABI allows fpu registers to be
> used when handing variable arguments. I think it is this issue that
> generally forces all PPC tasks to be floating point- its quite an
> annoying architectural property.
> So I'd like to propose that folks interested in the Virtex 4 gen405 bsp
> family have a look at the diffs and respond with issues & changes and
> hopefully I can commit something that doesn't cause too much trouble.
> If folks' email systems won't pass the attachment, then please email me
> and I'll resend directly.
> Thanks,
> Greg
> rtems-users mailing list
> rtems-users at rtems.com
