Xilinx IP core drivers for RTEMS- diff attached
Robert S. Grimes
rsg at alum.mit.edu
Thu Dec 21 15:09:29 UTC 2006
Okay, I've got major egg on my face! The "xilemac.c and xilemac.h are
identical" comment is false! Red Herring! My screw-up!
This morning, I decided to start over, and see if I can prove or
disprove it. So I started with a clean un-tar, applied the patch, then
looked at xilemac.h - lo and behold, it is now a real header file! I
still can't quite get it to build, though. Here is what I've found so
far...
First Attempt:
make all
- fails during compile due to missing xilemac.h file
Fix: cp <SOURCEROOT>/c/src/libchip/network/xilemac.h
<BUILDROOT>/gen405/lib/include/libchip
Second Attempt:
make all
- fails during compile due to missing opbintctrl.h
Fix: cp
<SOURCEROOT>/c/src/lib/libbsp/powerpc/gen405/include/opbintctrl.h
<BUILDROOT>/powerpc-rtems/gen405/lib/include
Third Attempt
make all
- fails during link due to error:
gen405/lib/librtemsbsp.a(startup.rel): In function `bsp_predriver_hook':
c/src/lib/libbsp/powerpc/gen405/startup/bspstart.c:107: undefined
reference to `opb_intc_init'
I haven't yet resolved the third problem, but I have narrowed it down a
wee bit. Seems
<ROOT>/c/src/lib/libbsp/powerpc/gen405/opbintctrl/opbintctrl.c is not
being compiled or included in the link.
I'll keep you informed, and once again, SORRY!!!
-Bob
Robert S. Grimes wrote:
> Wow! I don't know what happened, if it was the atuoconf/automake stuff
> or not, but I just realized in the source tree after patching, the files
> xilemac.c and xilemac.h are identical; specifically, they both contain
> what should be the .c contents! This explains why there is the #include
> directive! It may be my error, and I have to leave now so I can't
> confirm one way or the other, but my guess is that you might be sending
> xilemac.c to both the .c and .h files during configure. Of course, it
> may be I don't know what I'm talking about...
> More tomorrow...
> -Bob
> gregory.menke at gsfc.nasa.gov wrote:
>> Hi Bob,
>> There is only one xilemac.h, and it should be in libchip.
>> gen405/include/bsp.h is supposed to include libchip/xilemac.h, so it can
>> obtain driver definitions. I just checked the diff and it looks like I
>> screwed it up- I see the extra include as you say, but it does not exist
>> in my source. Beats me how I messed it up, but there you go...
>> With the gen405 in its present setup, I think xilemac would be better
>> located in the bsp than in libchip. If/when a virtex bsp shows up, then
>> xilemac could be copied into libchip- leaving the current version in
>> gen405 sort of like how the pc386 bsp has its own network drivers.
>> If/when gen405 moves to new_exceptions then maybe it could abandon its
>> internal xilemac in favor of the libchip version.
>> Given the above, I'd like to regenerate the diff with xilemac moved back
>> into the gen405 bsp, which makes sense given the old_exceptions and the
>> assumptions about the driver that the bsp makes. I'll try to get a new
>> patch out in a day or so, and please accept my apologies for the broken
>> diffs...
>> Regards,
>> Greg
>> Robert S. Grimes writes:
>> > Yes,
>> > It looks like $SOURCEDIR/c/src/libchip/network/xilemac.h (only xilemac.h
>> > I was able to find in source tree) is not making it into
>> > $BUILDIDR/powerpc-rtems/gen405/lib/include/libchip.
>> > I attempted to fix that by copying the file. However, when I did that,
>> > I got a problem about infinite include nesting; seems the file was
>> > including itself? Perhaps I am confused, but there is an include
>> > directive in xilemac.h like this
>> > #include <libchip/xilemac.h>
>> > If I comment that out, the infinite nesting problem goes away, but is
>> > replaced by these
>> > In file included from ../../../../.././gen405/lib/include/bsp.h:73,
>> > from
>> > ../../../../../../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc/old-exceptions/cpu.c:31:
>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:234: error:
>> > 'NUM_XILEMAC_UNITS' undeclared here (not in a function)
>> > ../../../../.././gen405/lib/include/libchip/xilemac.h: In function
>> > 'xilFifoRead32':
>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:270: error:
>> > 'XEM_PFIFO_RXDATA_OFFSET' undeclared (first use in this function)
>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:270: error: (Each
>> > undeclared identifier is reported only once
>> > ./../../../.././gen405/lib/include/libchip/xilemac.h:270: error: for
>> > each function it appears in.)
>> > 'xilFifoWrite32':
>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:309: error:
>> > 'XEM_PFIFO_TXREG_OFFSET' undeclared (first use in this function)
>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:318: error:
>> > 'DRIVER_PREFIX' undeclared (first use in this function)
>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:327: error:
>> > 'XEM_PFIFO_TXDATA_OFFSET' undeclared (first use in this function)
>> > 'xilGetWrFifo32VacancyBytes':
>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:363: error:
>> > 'xilFifoRead64':
>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:385: error:
>> > 'xilFifoWrite64':
>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:440: error:
>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:445: error:
>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:452: error:
>> > 'xilGetWrFifo64VacancyBytes':
>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:507: error:
>> > 'xilGetWrFifoVacancyBytes':
>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:533: error:
>> > 'xilEmacStop':
>> > ./../../../.././gen405/lib/include/libchip/xilemac.h:548: error:
>> > dereferencing pointer to incomplete type
>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:551: error:
>> > 'XEM_ECR_OFFSET' undeclared (first use in this function)
>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:555: error:
>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:559: error:
>> > and so on, especially the deref pointer errors.
>> > Seems something else is missing wrt the Xilinx definitions...
>> > Thanks,
>> > -Bob
>> > > Hi Robert,
>> > > Its likely something missing from the patch since I had a strip out a
>> > > lot of test things from the diff. I'll have a look at get back to you.
>> > > OTOH I continue to have problems with automake/autoconf occasionally
>> > > generating makefiles that need editing because its unclear which
>> > > versions work and which won't and RTEMS stays so close to the
>> > > toolchain's bleeding edge that its hard to tell. So there is some
>> > > possiblity that automake/autoconf issues could be causing trouble.
>> > > Greg
>> > > > Hi Greg,
>> > > > I attempt to build using your patches on a clean install of 4.6.99.3,
>> > > > and I get this error:
>> > > > Making all in powerpc
>> > > > make[5]: Entering directory
>> > > > `/cygdrive/c/Home/ll/etill/rtems-4.6.99.3/tools/b-rtems-4.6.99.3/powerpc-rtems/c/gen405/lib/
>> > > > libcpu/powerpc'
>> > > > if powerpc-rtems-gcc --pipe -B../../../../.././lib/
>> > > > -B../../../../.././gen405/lib/ -specs bsp_specs -qrtems -DPACKAGE_NA
>> > > > ME=\"rtems-c-src-lib-libcpu-powerpc\"
>> > > > -DPACKAGE_TARNAME=\"rtems-c-src-lib-libcpu-powerpc\"
>> > > > -DPACKAGE_VERSION=\"4.6.99.3\
>> > > > " -DPACKAGE_STRING=\"rtems-c-src-lib-libcpu-powerpc\ 4.6.99.3\"
>> > > > -DPACKAGE_BUGREPORT=\"rtems-bugs at rtems.com\" -I. -I../.
>> > > > ./../../../../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc -isystem
>> > > > ../../../../.././gen405/lib/include -I../../../../../
>> > > > ../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc/old-exceptions -Wall
>> > > > -mcpu=403 -D_OLD_EXCEPTIONS -Dppc405 -O4 -fno-keep-i
>> > > > nline-functions -g -MT
>> > > > old-exceptions/old_exceptions_rtems_cpu_rel-cpu.o -MD -MP -MF
>> > > > "old-exceptions/.deps/old_exception
>> > > > s_rtems_cpu_rel-cpu.Tpo" -c -o
>> > > > old-exceptions/old_exceptions_rtems_cpu_rel-cpu.o `test -f
>> > > > 'old-exceptions/cpu.c' || echo
>> > > > '../../../../../../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc/'`old-exceptions/cpu.c;
>> > > > then mv -f
>> > > > "old-exceptions/.deps/old_exceptions_rtems_cpu_rel-cpu.Tpo"
>> > > > l-cpu.Po"; else rm -f
>> > > > "old-exceptions/.deps/old_exceptions_rtems_cpu_rel-cpu.Tpo"; exit 1; fi
>> > > > ../../../../.././gen405/lib/include/bsp.h:73:29: error:
>> > > > libchip/xilemac.h: No such file or directory
>> > > > make[5]: *** [old-exceptions/old_exceptions_rtems_cpu_rel-cpu.o] Error 1
>> > > > make[5]: Leaving directory
>> > > > `/cygdrive/c/Home/ll/etill/rtems-4.6.99.3/tools/b-rtems-4.6.99.3/powerpc-rtems/c/gen405/lib/l
>> > > > ibcpu/powerpc'
>> > > > The "xilemac.h" file certainly does exist! It seems there's an include
>> > > > path problem. I'm going to try and track it down, but I thought you might:
>> > > > - know what I did wrong (if it's my mistake), or
>> > > > - want to know (if it's a patch problem).
>> > > > I will let you know what I find on my end.
>> > > > Thanks!
>> > > > -Bob
>> > > > > Hi,
>> > > > > I finally got back to some long-needed config management on the gen405
>> > > > > bsp. I assembled the diffs against 4.6.99.3, the file is attached for
>> > > > > review.
>> > > > > I hesitate to just check them in as some of the changes related to
>> > > > > uarts, fpu and memory map are highly idiosyncratic and I don't want to
>> > > > > mess up other people's work. I think a compromise patch might make the
>> > > > > most sense, where I set up a diff that preserves the general character
>> > > > > of the bsp; base addresses, etc.. but gets in the updated drivers.
>> > > > > Our bsp was peculiar in that the 405 units have 4 uarts and no fpu at
>> > > > > all, meaning, the entire toolchain has to be compiled with -msoft-float
>> > > > > to ensure nothing at all in newlib or above uses fp registers- the
>> > > > > va_args are problematic since the ppc ABI allows fpu registers to be
>> > > > > used when handing variable arguments. I think it is this issue that
>> > > > > generally forces all PPC tasks to be floating point- its quite an
>> > > > > annoying architectural property.
>> > > > > So I'd like to propose that folks interested in the Virtex 4 gen405 bsp
>> > > > > family have a look at the diffs and respond with issues & changes and
>> > > > > hopefully I can commit something that doesn't cause too much trouble.
>> > > > > If folks' email systems won't pass the attachment, then please email me
>> > > > > and I'll resend directly.
>> > > > > Thanks,
>> > > > > Greg
>> > > > > _______________________________________________
>> > > > > rtems-users mailing list
>> > > > > rtems-users at rtems.com
>> > > > > http://rtems.rtems.org/mailman/listinfo/rtems-users
