Changing compilation options for BSP building
Bruce Robinson brucer at pmccorp.com
Tue Feb 7 22:26:09 UTC 2006
Hi John,
I think the answer to your original question is that you need to edit the
line :
CPU_CFLAGS = -mcpu=cypress -msoft-float
in the make/custom/leon2.cfg file.
Best Regards,
Bruce
At 12:41 PM 2/7/2006, you wrote:
>Thanks for your quick answer Jiri but I intend to try this because I have
>the following problem :
>* I've got an application with several tasks and just one floating point
>task, I am targeting the AT697 from ATMEL that has a hardware FPU,
>* of course, I created the FP task with FP attribute,
>* when RTEMS switches to this task it does not restore the EF bit in PSR
>which implies an "FP disabled" trap on the first floating point instruction,
>* looking carefully at this problem under gdb I noticed that there was no
>fp_context pointer field in the thread structure associated with this task
>(this pointer is used to manage the fp_context in threadloadenv.c for
>example). So I assumed that there was something wrong in my bsp compilation.
>Therefore I found in thread.h that the fp_context field was enable/disable
>by CPU_HARDWARE_FP define which in turn is conditionned by SPARC_HAS_FPU
>define (in cpu.h) that is set or unset by _SOFT_FLOAT definition (in
>sparc.h). In cpu.h the
>CPU_SOFTWARE_FP  is also set to FALSE.
>As a consequence :
>-msoft-float option
>    implies (assumption based on comments in sparc.h)
>_SOFT_FLOAT in sparc.h
>    implies
>SPARC_HAS_FPU == 0 in sparc.h
>    implies
>CPU_HARDWARE_FP == FALSE in cpu.h
>+ CPU_SOFTWARE_FP set to FALSE in cpu.h
>    which implies a disabled FP management in threadloadenv.c that is part
> of the bsp.
>Can you see what's wrong in my approach ?
>John.
>----- Original Message ----- From: "Jiri Gaisler" <jiri at gaisler.com>
>To: "RTEMS Users Mailing List" <rtems-users at rtems.com>
>Sent: Tuesday, February 07, 2006 7:57 PM
>Subject: Re: Changing compilation options for BSP building
>>I would not recommend to remove the -msoft-float flag from
>>CPU_FLAGS. There is not floating point operations done in
>>the RTEMS kernel, hence you do not need to generate FPU
>>instructions. If you remove the -msoft-float option, newer
>>versions of gcc will use FPU registers for certain integer
>>operations (!) and the kernel will not run on processors
>>without an FPU. Hence, you do not gain anything by removing
>>-msoft-float, except the opportunity of crashing on non-FPU
>>LEON hardware.
>>Jiri.
>>John Pickwick wrote:
>>>Hi to all,
>>>What should I do to change the compilation options used during my bsp
>>>buid ?
>>>I use the LEON2 / RTEMS 4.6.5 BSP and I'd like to replace the "CPU_FLAGS
>>>= -mcpu=cypress -msoft-float" option used during the compilation to
>>>suppress the soft-float setting.
>>>I tried to set CC_FLAGS_TARGET or CPU_FLAGS directly on my configure
>>>command line but it does not work (failed with an 'invalid build alias'
>>>error).
>>>Thanks for help,
>>>John.
