Building from CVS
Ian Caddy ianc at goanna.iinet.net.au
Wed Feb 8 04:38:01 UTC 2006
Hi Brian,
You need to go to the source root directory, and run the following command:
./bootstrap
This will create your configure script based on your system.
I hope this helps.
regards,
Ian Caddy
Brian Rose wrote:
> I just downloaded from CVS and I see there is no configure script. What
> is the proper invocation of autoconf needed to properly generate it. Is
> it as simple as "autoconf" ?
Ian Caddy
Goanna Technologies Pty Ltd
+61 8 9221 1860
