Building from CVS
Wed Feb 8 12:11:30 UTC 2006
Ralf Corsepius wrote:
>On Tue, 2006-02-07 at 22:34 -0500, Brian Rose wrote:
>>I just downloaded from CVS and I see there is no configure script. What is
>>the proper invocation of autoconf needed to properly generate it. Is it as
>>simple as "autoconf" ?
>You'll have to have the RTEMS versions of autoconf and automake
>installed (available somewhere on ftp.rtems.org) and in $PATH, then
>cd <source-tree>
>./bootstrap
>should create all the necessary files.
Just make sure to use the RTEMS provided versions of autoconf and automake.
But it is just that easy.
>Ralf
