Where I can find a simple posix RTEMS example + Makefile ?
Matteo matteo.posterli at studenti.unipr.it
Tue Feb 14 16:00:24 UTC 2006
Yes, I see it but when I compile rtems I do --enable test and I have the
directory where there is all the psx example compiled yet. So I take the psx's
sources examples from the source of rtems but there isn't the makefile and if
I try to compile it with the makefile of Hello_World, just modified the target
file, I have a lot of error, may be I could do some changes to the makefile
but I don't wich.
I try to run a psx example compiled yet and works well so I think to have
configured good RTEMS.
Can you help me to find a right Makefile to compile the psx example ?
Scrive Ralf Corsepius <rc040203 at freenet.de>:
> On Tue, 2006-02-14 at 14:09 +0100, Matteo wrote:
> > Hi
> > where I can find a simple example of posix threads with RTEMS
> There is a whole posix testsuite inside of the source tree (check for a
> directory named psxtests)
> Ralf
