termios raw question
Eric Norum norume at aps.anl.gov
Tue Feb 14 16:10:28 UTC 2006
If your code is looking for  '\n' to terminate the read, and the
device is actually sending a '\r' then you'll never see an 'end-of-
line' unless ICRNL is set.
i.e. if your code looks something like:
	for(;;) {
		read(fd,&c,1);
		if (c == '\n')
			break;
		buf[i++] = c;
then you must have IRCNL set.....
On Feb 14, 2006, at 6:03 PM, Jennifer Averett wrote:
> I'm trying to use termios for reading/writing a raw data stream.
> I am using tcgetattr to get the attributes then setting:
>   termios_attr.c_iflag &= ~(IXON|IXANY|IXOFF);
>   termios_attr.c_oflag &= ~OPOST;
>   termios_attr.c_lflag &= ~(ECHO|ECHONL|ICANON|ISIG|IEXTEN);
>   termios_attr.c_cflag = CREAD;
>   termios_attr.c_cflag &= ~(CSIZE|PARENB);
>   Setting Baud rate in c_cflag based upon a table value
>   Setting bits per charachter in c_cflag based upon a table value
>   Setting parity in c_cflag based upon a table value
>   Setting number in c_cflag of stop bits based upon a table value
>   Settiing flow control in c_iflag based upon a table value
> Then I use tcsetattr to set the attribute.  I found a problem where
> 0xd
> was being changed to a 0xa with this code and replaced the first
> c_iflag
> setting with:
>   termios_attr.c_iflag &= ~(IXON|IXANY|IXOFF|ICRNL);
> However this causes a queue overflow when reading the device.  Does
> anyone
> know if clearing ICRNL, would have the effect of hoarding input
> characters
> and if so how to keep this from happening?  Any other suggestions
> would be
> appreciated.
> Jennifer
Eric Norum <norume at aps.anl.gov>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
