gettimeofday seconds rollover problem?
Eric Norum norume at aps.anl.gov
Fri Feb 24 19:42:13 UTC 2006
> Ultimately, however, the OS' sync. primitives do disable thread-
> dispatching and/or
> interrupts so introducing a memory barrier there should be good
> enough.
> IMO, the memory barrier is fine for thread-dispatch but I'm still a
> little bit sceptical
> about introducing it to rtems_interrupt_disable/enable (especially
> on a RISC machine).
Can you try a couple tests and confirm your suspicions?
Your suggestion to add the barriers to the _ISR_Enable/Disable/Flash
macros seems like a very simple and robust solution (if your
suspicions aren't confirmed....)
> T.
>>> Nobody has addressed my point # 1: adding a memory barrier
>>> to rtems_interrupt_disable/enable does not address thread-
>>> dispatch- disable
>>> protected code. If we're going to add this safe-guard, it should
>>> be introduced to thread_dispatch_disable/enable, too.
Eric Norum <norume at aps.anl.gov>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
