gettimeofday seconds rollover problem?
Till Straumann strauman at slac.stanford.edu
Fri Feb 24 21:05:30 UTC 2006
Pavel Pisa wrote:
>Hello All,
>On Friday 24 February 2006 18:36, Till Straumann wrote:
>>      #define _ISR_Disable( _level ) \
>>              _CPU_ISR_Disable( _level ) \
>>              asm volatile("":::"memory")
>Great.
>I have only concern about syntactical correctness of this construct
>and behavior in if() x; else y; flow. I would modify it next way
>              do { _CPU_ISR_Disable( _level ); \
>              asm volatile("":::"memory"); } while(0)
Yes, of course, you're right, thanks.
T.
