gettimeofday seconds rollover problem?
    Pavel Pisa
    ppisa4lists at pikron.com
    Tue Feb 28 08:19:06 UTC 2006
On Tuesday 28 February 2006 08:23, Thomas Doerfler (nt) wrote:
> >   loc_var=AS_VOLATILE(*glob_var_ptr)
> >   loc_var=AS_VOLATILE(glob_var)
> >   AS_VOLATILE(*glob_var_ptr)=loc_var
> Shouldn't it be something like this:
> #define AS_VOLATILE(x) (*(volatile typeof(&(x)))(&(x)))
:-) Late night syndrome stroked me again, thanks.
> Apart from the missing "volatile", I think this construct has nice
> features. It will mark, which accesses are really required to be "safe".
> The disadvantage is, that all the locations using
> interrupt_disable/enable are required to be revised.
> Therefore I would tend again to use the "memory barrier" method as it is
> more robust (with the disadvantage of loosing some performance).
I am personally voting for and prefer barriers all the time.
But because there are some concerns about that solution,
I am trying to to think and disturb others peace in other
directions as well.
To remind, my vote is to add missing "cc" into
m68k_enable_interrupts and use Till Straumann's idea
      #define _ISR_Disable( _level ) \
              do { _CPU_ISR_Disable( _level ); \
              asm volatile("":::"memory"); } while(0)
      #define _ISR_Enable( _level ) \
              do { asm volatile("":::"memory"); \
              _CPU_ISR_Enable(); } while(0)
      #define _ISR_Flash( _level ) \
              _CPU_ISR_Flash( _level ); \
May be, the  construct
should be hidden by some macro to leave code portable to non-GCC
compilers. It should be something like _CPU/_SCORE_LOCAL_MEMORY_BARRIER().
It should be evident, that it is not equivalent to physical memory barriers
required for ensuring coherence in MP/DMA/coprocessor cases on the most
of the targets.
Best wishes
              Pavel Pisa
