gettimeofday seconds rollover problem?
Tue Feb 28 08:51:19 UTC 2006
Joel Sherrill wrote:
> I agree.  If volatile is sufficient, then I don't want to do anything else.
What audit process are we going to use to know we have 100% kernel
coverage ?
My understanding is a barrier provides this. I see volatile as having
possible leaks (which we should fix). To be honest I do not have a clear
enough picture to forcefully comment further.
FWIW FreeBSD for the i386 port has in src/sys/i386/include/cpufunc.h:
static __inline void
disable_intr(void)
	__asm __volatile("cli" : : : "memory");
enable_intr(void)
	__asm __volatile("sti");
  [ Note, the barrier is only on disable ]
These systems are concerned about SMP issues and here ordering is a
larger more complex problem.
> Can those who have been looking at the generated code try volatile on
> the list of variables I proposed?
I have played with a barrier, and volatile _Thread_Heir. I tried all
combinations and the results have 'v' for volatile _Thread_Heir and 'b'
for the barrier. The result with gcc 4.1.0 for the Coldfire av5282 BSP are:
$ m68k-rtems4.7-size minimum.nxe
    text    data     bss     dec     hex filename
   81072    2480    6832   90384   16110 minimum.nxe
$ m68k-rtems4.7-size minimum-v.nxe
   81056    2480    6832   90368   16100 minimum-v.nxe
$ m68k-rtems4.7-size minimum-b.nxe
   81056    2480    6832   90368   16100 minimum-b.nxe
$ m68k-rtems4.7-size minimum-bv.nxe
   81040    2480    6832   90352   160f0 minimum-bv.nxe
I am now looking to see what code changes. Not an easy diff to do but I
am making progress. I will also rerun the tests to confirm the results.
I would like to understand this a little more.
Regards
