Problem when compiling gcc for rtems-4.6 toolchain
Dominik Brader dbrader at gmx.net
Tue Feb 28 23:36:50 UTC 2006
On Tuesday 28 February 2006 21:59, you wrote:
> Dominik Brader wrote on 2/28/06 12:45 PM:
> > Hello,
> > I have a problem when compiling the gcc for the RTEMS-4.6. toolchain.
> > I am using binutils-2.13.2.1, gcc-3.2.3 with
> > gcc-3.2.3-rtems-20040420.diff patch and newlib-1.11.0 with
> > newlib-1.11.0-rtems-20030605.diff patch.
> > My configuration for the gcc is:
> > ../gcc-3.2.3/configure --target=sparc-rtems --enable-languages="c,c++"
> > --prefix=$PREFIX --with-newlib
> > --with-headers=$TOOLCHAIN/newlib-1.11.0/libc/include
> > The Error message is attached below.
> > The native compiler on the system is gcc-3.2.3, but I also tried
> > gcc-3.3.2 with the same result.
> > The strange thing about it is that it works fine if I just configure
> > without c++ support. But then I can't compile RTEMS, is that right?
> > Can anybody help me with this?
> > Dominik
> > Error-Message:
> > gcc -DIN_GCC -DCROSS_COMPILE   -g -O2 -W -Wall -Wwrite-strings
> > -Wstrict-prototypes -Wmissing-prototypes -Wtraditional -pedantic
> > -Wno-long-long  -DHAVE_CONFIG_H  gcov.o intl.o
> > version.o   ../libiberty/libiberty.a -o gcov
> > /opt/TWWfsw/gcc332/i686-pc-linux-gnu/bin/ld: cannot open crt0.o: No such
> > file or directory
> > collect2: ld returned 1 exit status
> > make[1]: *** [gcov] Error 1
> > make[1]: Leaving directory
> > `/home/braderdo/project-work/rtems/sparc-rtems-toolchain2/tools/build-gcc
> >/gcc' make: *** [install-gcc] Error 2
> Dominik,
> Did you put a symbolic link to newlib in gcc? Also, is newlib-1.11.0 the
> right vintage for rtems-4.6.?
> --John
Yes I followed the instructions in the rtems-documentation... I also tried
different configurations. But without success.
