Problem with thread posix
Matteo
matteo.posterli at studenti.unipr.it
Mon Feb 13 11:32:12 UTC 2006
Scrive Chris Johns <chrisj at rtems.org>:
> [ Should this email be back on the list ? ]
> >>Matteo wrote:
> >>>But I have error on all the pthread_create, pthread_mutex_lock/unlock,
> >>>pthread_cond_signal as all the posix parameters are not configured.
> >>What is the error message ?
> >>Regards
> >>Chris
> > I control that the mutex lock/unlock or the signal are good with a simple
> > control like this ;
> > if(pthread_mutex_lock(&mutex)) perror("Error mutex");
> > or
> > if(pthread_mutex_unlock(&mutex)) perror("Error unlock mutex");
> > or
> > if (pthread_cond_wait(&b->cond, &b->mutex)) perror("Error wait");
> > and so on for all the other thread posix commands, and I have that there
> is
> > always error ! But if I compile the code normally under linux I have no
> problem,
> > so the code for the linux compiler is good, but not for rtems! (I have
> installed
> > RTEMS 4.6.99.2)
> > So, have you some idea?
> What is the configuration table parameters for POSIX ?
> Linux does not have the same setup issues RTEMS has. RTEMS is embedded
> so allows you the ability to constrain resources, ie has a configuration
> table.
> Can you run any of the POSIX tests ?
> Regards
> Chris
Yes I can run all the posix example of the testsuite, because I enable tet suite
when I configure rtems, but in the test suite I have no the source file only the
*.exe file !
So if I try to launch the psx example *.exe I have no problem. I find the source
of the psx example but I haven't the makefile, infact if I try to launch the
source with a makefile of Hello_world I have a lot of error !
So May be I need of particular option in the makefile to compile correctly my
posix example.
What do you think?
