Truble Building tools for 4.6.4
Ralf Corsepius ralf.corsepius at rtems.org
Thu Feb 23 06:01:18 UTC 2006
On Thu, 2006-02-23 at 14:28 +1100, Angelo Fraietta wrote:
> Chris Caudle wrote:
> > On Wednesday 22 February 2006 19:52, Angelo Fraietta wrote:
> >>It all works fine on my Mac OSX machine, but on the linux machine it
> >>will not compile.
> > What version is the native gcc on Mac OSX?
> 3.3.2
> gcc has changed a lot in the
> > intervening years since 4.6.4 was released.  On a Fedora Core 4 machine, gcc
> > 3.2.3 is available as gcc32.  It might be worth trying again, but using gcc32
> > instead of gcc as the native compiler.
> On Linux it is 4.0.0
Please re-read, what Chris wrote: You should try the Fedora package
called "gcc32" to build the gcc-3.2.3 RTEMS-4.6.x depends upon.
> Will the latest RTEMS version run on both?
I don't understand what you are asking.
Your problem here is: gcc-3.2.3 is too outdated to be compilable by
gcc-4.x.
Ralf
