gettimeofday seconds rollover problem?
Joel Sherrill
joel.sherrill at oarcorp.com
Thu Feb 23 12:20:07 UTC 2006
Chris Johns wrote:
> Joel Sherrill wrote:
>> The seconds and nanoseconds values are grabbed/computed with interrupts
>> disabled so I don't think that would be the problem.
> No they are not and it is the problem. The interrupts are being enable
> just after they are being disabled. Here is the code:
> 00000000 <gettimeofday>:
> gettimeofday():
> ../../../../../head/cpukit/libcsupport/src/__gettod.c:50
> 0: 4e56 0000 linkw %fp,#0
> 4: 206e 0008 moveal %fp@(8),%a0
> ../../../../../head/cpukit/libcsupport/src/__gettod.c:55
> 8: 4a88 tstl %a0
> a: 6736 beqs 42 <gettimeofday+0x42>
> ../../../../../head/cpukit/libcsupport/src/__gettod.c:67
> c: 203c 0000 0700 movel #1792,%d0
> 12: 2200 movel %d0,%d1
> 14: 40c0 movew %sr,%d0
> 16: 8280 orl %d0,%d1
> 18: 46c1 movew %d1,%sr
> ^^^^^^^^^^^^^ DISABLED
> ../../../../../head/cpukit/libcsupport/src/__gettod.c:70
> 1a: 46c0 movew %d0,%sr
> ^^^^^^^^^^^^^ ENABLED
> The remainder of the code is the reading of the time:
> ../../../../../head/cpukit/libcsupport/src/__gettod.c:72
> 1c: 2039 0000 0000 movel 0 <gettimeofday>,%d0
> 22: 0680 21da e500 addil #567993600,%d0
> 28: 2080 movel %d0,%a0@
> ../../../../../head/cpukit/libcsupport/src/__gettod.c:73
> 2a: 2239 0000 0000 movel 0 <gettimeofday>,%d1
> 30: 2039 0000 0000 movel 0 <gettimeofday>,%d0
> 36: 4c00 1800 mulsl %d0,%d1
> 3a: 2141 0004 movel %d1,%a0@(4)
> 3e: 4280 clrl %d0
> 40: 6010 bras 52 <gettimeofday+0x52>
> ../../../../../head/cpukit/libcsupport/src/__gettod.c:56
> 42: 4eb9 0000 0000 jsr 0 <gettimeofday>
> 48: 2040 moveal %d0,%a0
> 4a: 20bc 0000 000e movel #14,%a0@
> 50: 70ff moveq #-1,%d0
> 52: 4e5e unlk %fp
> 54: 4e75 rts
> I wonder where else in the kernel this is happening and to which other
> targets. I see the i386 also has problems. In the i386 only one value
> is being read with interrupts masked:
> rtems_interrupt_disable(level);
> c: 9c pushf
> d: fa cli
> e: 58 pop %eax
> cpukit/libcsupport/src/__gettod.c:69
> seconds = _TOD_Seconds_since_epoch;
> microseconds = _TOD_Current.ticks;
> f: 8b 15 18 00 00 00 mov 0x18,%edx
> ^^^^^^^^^^^^^^^^ ONLY ONE READ
> rtems_interrupt_enable(level);
> 15: 50 push %eax
> 16: 9d popf
> tp->tv_sec = seconds + POSIX_TIME_SECONDS_1970_THROUGH_1988;
> 17: a1 00 00 00 00 mov 0x0,%eax
> ^^^^^^^^^^^^^^^ THE OTHER READ
> 1c: 05 00 e5 da 21 add $0x21dae500,%eax
> 21: 89 01 mov %eax,(%ecx)
>> The asm volatile statements
>> should provide sync points for the compiler if a partial read of
>> memory were
>> an issue.
> If this is the case it would seem we have a problem with our asm
> statements or the compiler has a bug.
This is the C code we are looking at the assembly for, correct?
and the assembly inlines for that are:
#define m68k_disable_interrupts( _level ) \
do { register uint32_t _tmpsr = 0x0700; \
asm volatile ( "move.w %%sr,%0\n\t" \
"or.l %0,%1\n\t" \
"move.w %1,%%sr" \
: "=d" (_level), "=d"(_tmpsr) : "1"(_tmpsr) ); \
} while( 0 )
#define m68k_enable_interrupts( _level ) \
asm volatile ( "move.w %0,%%sr " : : "d" (_level));
Which compiler did you check that with?
> Regards
> Chris
