gettimeofday seconds rollover problem?
Till Straumann
strauman at slac.stanford.edu
Fri Feb 24 19:24:38 UTC 2006
Eric Norum wrote:
> On Feb 24, 2006, at 11:36 AM, Till Straumann wrote:
>> Eric Norum wrote:
>>> 1) The _TOD_* variables must be declared as volatile since their
>>> values can change in a fashion (Deus ex machina) not apparent to
>>> compiler.
>>> 2) The M68K_BARRIER macro, or its equivalent addition to the
>>> enable/ disable macros, is required to keep the optimizer from
>>> hoisting/ sinking any code beyond the interrupt disable/enable
>>> operations. My feeling is that it's clearer and simpler to just
>>> add the "memory", "cc" to the disable/enable macros, but I'm not
>>> dogmatic about this.
>>> These two steps seem very clear to me since they impart to the
>>> compiler exactly the information needed. Both steps are necessary
>> This is not true. Only the 'volatile' declaration of global variables
>> that are accessed during any kind of 'inlined' protection mechanism
>> (be it interrupts, thread-dispatching, mutex, ...) is necessary
>> (and sufficient).
> I'm not sure what you're trying to get across here. It seems to me
> that any global variable shared amongst threads (or amongst threads
> and interrupt handlers) has to be declared volatile regardless of
> whether it's accessed from inside an inlined protection mechanism or
> accessed from anywhere else.
Not really. Usually you would use traditional 'mutex'es (or other
synchronization primitives)
to guarantee consistency.
Only if the mutex take/release operations are inlined then you could
face the
same problem (and that was my point).
Ultimately, however, the OS' sync. primitives do disable
thread-dispatching and/or
interrupts so introducing a memory barrier there should be good enough.
IMO, the memory barrier is fine for thread-dispatch but I'm still a
little bit sceptical
about introducing it to rtems_interrupt_disable/enable (especially on a
RISC machine).
T.
>> Nobody has addressed my point # 1: adding a memory barrier
>> to rtems_interrupt_disable/enable does not address thread-dispatch-
>> disable
>> protected code. If we're going to add this safe-guard, it should
>> be introduced to thread_dispatch_disable/enable, too.
> Agreed.
>> BTW: I don't think we should modify all the ports! We should just
>> change score/isr.h:
>> #define _ISR_Disable( _level ) \
>> _CPU_ISR_Disable( _level ) \
>> asm volatile("":::"memory")
>> #define _ISR_Enable( _level ) \
>> asm volatile("":::"memory") \
>> _CPU_ISR_Enable()
>> #define _ISR_Flash( _level ) \
>> _CPU_ISR_Flash( _level ) \
>> _Thread_Disable_dispatch() should be treated alike.
>> -- Till
> Excellent solution!
> Who's going to commit this?
