Problems redirecting stdin/out for a task in 4.6.99.2
Brett Swimley
brett.swimley at aedbozeman.com
Thu Jan 5 21:24:04 UTC 2006
Till -
I'm noticing something similar to this with the rtems_monitor
(mon-monitor.c). I tried your change by adding
fileno(STDIN_FILENO);
prior to the tcgetattr, and tcsetattr calls for STDIN_FILENO.
I also tried fileno(stdout) as you suggested.
Still no luck.
Any other thoughts or comments?
Regards,
Brett Swimley
Till Straumann wrote:
>Hmm - I do something very similar in a modified version of telnetd.c and
>indeed did observe
>something similar.
>>- has anybody already fixed this?
>Here's my workaround:
> /* newlib hack/workaround. Before we change stdin/out/err we must make
> * sure the internal data are initialized (fileno(stdout) has this
>sideeffect).
> * This should probably be done from RTEMS' libc support layer...
> * (T.S., newlibc-1.13; 2005/10)
> fileno(stdout);
>HTH
>-- Till
>>wkr,
>>Thomas Doerfler.
